Power doesn't work but clock is on?
dr tim
I need help, having a christmas party tonight and my Polk isonic 2 displays the clock but nothing else works. I tried unplugging and plugging back in, it reboots but again, just the clock is on, I press the power button and nothing, any ideas? Is there a system reset?
Post edited by dr tim on
Just me or does this person make a new account for every question?Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
hmmm, nguyendot, you are right , this is becoming interesting...
OP if you purchased this from an authorized dealer you may contact out customer service monday @ 1-800-377-7655 9am-5:30 pm, if purchased from an un-authorized deal you will not have a polk audio warranty -
I would suggest that you put it in the bath tub and fill it with hot water. Let it soak for about 47 to 53 minutes and then put in the clothes dryer on low heat or the "fluff" cycle for 'bout 13 minutes. Then be sure to plug it into a good 480 3 phase receptacle and power it on and off 7 times. This will unlock it.:cool:Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404
