SDA 2, some speakers not firing question.
MileHigh10B
I went to listen to the SDA 2's. The outer vertical row of one, 6.5" mid and one, one inch tweeter were not working. I looked in the back and the IC cable had disconnected itself. I plugged it in and they still did not work with all the other speakers working fine. It is the same on both speakers. The outer row not firing. The IC cable looks bent pretty good like the speaker was shoved hard against the back wall and put a crimp in it. So any of you know why the outer row of speakers on both would not be firing? These are the speakers in Denver on another listing here. Thanks Rick
Hello,
If the SDA cable is defective there won't be any sound produced by the SDA drivers. This would be the outside drivers of each speaker. You would need to check the SDA cable for end-to-end continuity. Do you have a Volt/Ohm meter?
Cheers, Ken
