Rotel rb-1080 where can i get it fixed
Neale13
Neale13 Posts: 88
edited December 2009 in Troubleshooting
HI I HAVE A ROTEL RB-1080 AMP. ONE CHANNEL SEEMS TO BE OUT. IS THERE ANY PLACE IN THE BALTIMORE AREA I CAN TAKE THIS AMP TO GET FIXED ? INSTEAD OF SENDING IT BACK TO ROTEL. I HAVE A HOLIDAY PARTY COMING UP QUICK AND I NEED IT .THANKS FOR YOUR HELP:confused::confused::confused:
Post edited by Neale13 on
  • miner
    miner Posts: 1,305
    My guess it is a fuse that has blown - common with RB-1080. I would first remove the cover (unplugged of course) and check the internal fuses. Rotel's CS would be able to tell you what to replace it with - RShack should have some replacement fuses. Get extras, because it will happen again.
