GNX104 question
Zades
I've just bought and received two Polk GNX 104s from Crutchfield with the suggested 0.65 cu.ft sealed boxes. In addition, I have a Pioneer Premier 550MP (w/ WMA and MP3 playback); two US Acoustic 2100 (300x1 @ 4 ohms); and one 1-farad capacitor to keep everything clean. Oh yeah, I also have Infinity Reference 6.5" coaxs in the doors and I-R 6x9s in the rear deck...
---Honda Accord '98 LX--
I have also installed 6x9 inch baffles in the rear so that the airpressure from my subs don't affect the 6x9's cone excursion
I thought that the system would be a beauty to behold...Power, Accuracy...elegance...:-)
Well, that's simply not the case...
I am most disappointed in my subs...for the Infinities are doing wonders with the mids and highs as I wanted them to do...but the subs are truly unsatisfactory
I have positioned my sub box in every possible way, and I remain displeased...
As with anything, at low volumes the sub sounds pretty good, but once I start towards higher volumes, there is much bass distortion and clipping...and I have yet to hear them "pound" as reviews that I have read professed.
I hypothesize that my box is too small and actually have Acousti-stuf to increase the apparent size (2 lbs of the stuff). However, as I have done since I was twelve (and am now 20) I drill my holes by hand, and I would hate to take the subs out put the material in and still be displeased.
Anyone have any ideas?
"Nothing is Impossible"
Post edited by Zades on
Well, you might try posting this in the car catagories.
I had one GNX104 in my wagon and it hit fairly hard. I went to a Polk/MOMO 12" and it got SIGNIFICANTLY better.
Try the stuffing, as it's cheaper than getting new subs.LSi 9/C/FX
Arcam AVR-200
