PSW505 surround issue
clukowicz
clukowicz Posts: 6
edited December 2009 in Troubleshooting
Hi,
I have a brand new PSW505 I received from Newegg a couple of weeks ago. The foam surround has a one inch section that is loose - looks like whatever was used to seal it at the factory got brittle or was weak to begin with. If I push it back in, it flattens out, but once the sub gets up to a decent volume, that section pops out, so it isn't completely sealed. Does anyone have suggestions as to how to repair this? Some audio video forums I have seen suggest using aquarium silicone to stick it back into place.
Post edited by clukowicz on
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    Try contacting The Egg and see what they can do for you. If not Polk CS is second to none, they will hook you up. Their number is 1-800-377-7655, or maybe Eric, or somebody else from Polk CS will see your post, they are in here quite a bit. Welcome to Club Polk.
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • clukowicz
    clukowicz Posts: 6
    Unfortunately, Newegg is of no help as far as their return policy goes. Doesn't seem to be affecting the sound, so I don't know how serious this really is. If possible, I'd rather fix myself instead of going to the trouble to ship it to a repair facility.
    Jeff is right give Polk Customer Service a call...they'll advise and help you resolve this to your satifaction...perhaps even send you what you need for the repair if you want to go that route!
    cnh
  • clukowicz
    clukowicz Posts: 6
    Thanks for the tips. From doing some more research on the web, I may have my terminology wrong. I don't think it's the surround (sounds like that's physically part of the cone) - it's the foam gasket that is between the edge of the cone and the subwoofer cabinet. A 1 inch piece has separated. I'm starting to upgrade my equipment from a cheap HTIB system, and this is the first component I've upgraded, so I'm new to this stuff.... :)
    You're OK, that's normally called a foam (or rubber) surround so you're good;; we understand what you mean....it's rare for the foam to come loose this early. But CS will take care of you...don't worry!!
    cnh
  • wutadumsn23
    +1 Contact Polk CS, you will not be dissapointed. May be a pain to ship and what not, but I promise you will be happy with the result.
    -Jeff
    HT Rig
    Blu-Ray- 80 GB PS3
  • john E
    john E Posts: 32
    maybe they did't get it glued good ,the foam usely last for a long time unless you have it cranked up all with way and have the amp db level cranked up to high and blew it apart.They are very stiff when you first get them ,I just turned mine up a quarter of the way until I get it broke in.That can take 50 hours or more to break them in proper.
    ONKYO TX-SR607
    PolkAudio Speakers
    Front-Monitor 70's
    Center-CS2
    Sur-round-Monitor 40's
    Sur-round Back-Monitor 60's
    Subwoofer-PSW-505
    Back fill in Bass PSW-10
    LG 50"Black 1080P Plasma HDTV (50PS60)
    LG Blu-Ray Disc BD390
  • dvran
    dvran Posts: 280
    Get an RMA form from Newegg and send it back. Let them deal with Polk.
    ~Dan
    Projector: Epson 705HD on 106" DaLite
    TV: Samsung 50" Plasma PN50B550
    Receiver: Onkyo 607
    Fronts: Polk 1000i
    Center: Polk Csi40
    Rears: Polk Fxi30
    Sub: Velodyne Minivee 10
    PS3 and Xbox
  • clukowicz
    clukowicz Posts: 6
    I definitely didn't crank it up all the way. The volume is set to 4, and I haven't changed the db level on the receiver. Newegg won't take a return for this item unless it is damaged in shipment and you refuse delivery.
  • concealer404
    concealer404 Posts: 7,440
    Have you called Newegg directly? That seems unlike them. I've RMA'd a lot of things through them with no hassles.
  • clukowicz
    clukowicz Posts: 6
    Is anyone from Polk CS online that can provide an answer to this? Otherwise I'll call....
  • clukowicz
    clukowicz Posts: 6
    I contacted Polk CS by e-mail yesterday and got a response within an hour. Turns out it's just a foam gasket covering the mounting screws. They're mailing me a replacement. Way to go Polk!!
  • wutadumsn23
    See post 2, 4 and 7, lol. J/K, see I told you they would hook you up. One of the reasons I bought Polks in the first place is because of their CS. Glad they got you all fixed up.
    -Jeff
    HT Rig
    Blu-Ray- 80 GB PS3
