Rti A5 mid woofer buzzzzz
Bluto
Bluto Posts: 18
edited December 2009 in Troubleshooting
The bottom midwoofer in one speaker is buzzzzzzing on tracks with deep bass lines? Pulled the driver twice to make sure nothing is touching the cone. Driver is mounted frimly what next?
Fronts - RTi A5s
Sub - DSW Pro 600
Jolida 202A
NAD C515BBE
Audio gd DAC 19MK3 "B"
Monster Power HTS 5100 MKII
Post edited by Bluto on
  • packetjones
    packetjones Posts: 1,059
    I am not sure of how to fix it myself but i would be calling Polk customer service. I am sure that they would be able to give you some advice. Also if it is under warranty they would probably fix it for you.
    Sorry i couldnt be more help. maybe some of the others will have some ideas on what else to check.
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • SolidSqual
    SolidSqual Posts: 5,218
    I had this on a new pair of RTIa9s I purchased. My lower mid-woofer was bad. Polk sent me a new one. Problem solved. Just locate which woofer is buzzing. Then call Polk and get a new one.
  • Bluto
    Bluto Posts: 18
    Thanks guys! I spoke with a guy at Polk today and he gave me a few things to try. He made it sound like I could order the part on this site somewhere and would get 20% off for being a member? maybe I didn't hear him right because I cant find the parts section he mentioned anywhere?
    Fronts - RTi A5s
    Sub - DSW Pro 600
    Jolida 202A
    NAD C515BBE
  • SolidSqual
    Bluto wrote: »
    Order through the customer support hotline or the online tech support during business hours.
