POP Sound When Changing Channels
peeplwtchr
peeplwtchr Posts: 7
edited December 2009 in Troubleshooting
Hi All-
I just noticed that I hear a crack or pop sound through my RC85's when I change TV channels. Anyone know why? How do i fix this?
My system config. is below:
4-RC85 in ceiling
CS 10 center
Yamaha vx 463 rec.
Thanks in advance
Todd
Post edited by peeplwtchr on
  • vc69
    vc69 Posts: 2,500
    Are you using the variable output jacks on your cable box? Are you using a cable box? How are you connected? We need a bit more info to provide any real help...
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • peeplwtchr
    peeplwtchr Posts: 7
    Thanks-
    I have the cable connected right to my TV (NO cable box), I have an optical sound cable going from TV to receiver. And I have the video connected via Composite Video cable from TV to the receiver as well.
