(potential) problem with one Rtia5
Norm Apter
Norm Apter Posts: 1,036
edited November 2009 in Troubleshooting
I haven't moved my pair of Rtia5s around too much since purchasing them just under a year ago, however, when I was trying out some listening positions the other day, I noticed that in one (but not both) of the Rtia5 speakers there was a rattling noise (as if something is loose and moving around independently) inside the speaker, near the bottom.
Had I not moved it around, I wouldn't have noticed. I hadn't noticed any sonic problems with this speaker, and just ran a very preliminary test to try to compare one against the other and, at first listen, couldn't discern a difference.
My question is: what might this rattling noise be? And more important, is it crucial? Is there something I should do to try to rectify the situation?
I bought these new from an authorized dealer (Electronics Expo) and registered them last December so they should be covered under Polk's 5-year warranty, however, I don't want to make a big deal out of this if its not. If anybody has any ideas on this issue, please let me know.
2 Ch.
Parasound Halo A23 Amp
Parasound Halo P3 Preamp
Parasound Halo T3 Tuner
Bada HD22SE tube CD Player
Magnum Dynalab Signal Sleuth
Magnum Dynalab ST-2 antenna
polkaudio Lsi9s (upgraded cross-overs)
MIT Shotgun S-3 Bi-wire Interface Speaker Cables
MIT Shotgun S-3 Interconnects (3)
IegO L70530 Power cords (3)
HT
Denon 2808ci AVR
polkaudio RTi A5s (fronts)
polkaudio RTi A1s (rears)
polkaudio Csi A6 (center)
Signal Cable Ultra Speaker Cables
Signal Cable Analog II Interconnects
Post edited by Norm Apter on
  • rallyshark
    rallyshark Posts: 417
    I don't know how picky Polk would be about a warranty repair if you removed a driver to look, but that's what I would do. It could be something really simple and easy to fix yourself. In which case, you will have saved yourself and Polk some trouble:) Polk would definitely take care of it for you, but that's a lot of trouble I wouldn't want to deal with if I could just remove a driver and tidy up some dangling wires or snap something back into place etc.. I'm sure someone else will chime in with better advice though. Good luck!
    Sony 40" LCD
    Sony DVPCX995V
    Sony PS3(games/media server)
    Sony PS2
    WD TV Live with 3TB
    Sanyo VCR
    Marantz SR6003
    Polk 11T(xover/RDO)
    RM20 5 pack
    OWM 5
    DUAL Micro Pro 1000
    Combastard Cable
    Harmony One
    When rapture comes, can I have your car?
  • dorokusai
    dorokusai Posts: 25,577
    Open it up and look.
