Sony needs a firmware update for the PS3 for CD playback
Ron-P
Ron-P Posts: 8,520
edited November 2009 in Electronics
With the PS3 wired into my Onkyo via HDMI I am unable to play a CD unless I turn the display on. Being that I have a FP I'm not going to do this just to make the connection so the CD will play.
Come on Sony, it cannot be too difficult.
If...
Ron loves a film = don't even rent.
Post edited by Ron-P on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    Maybe someone needs a better player ;)
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • LessisNevermore
    LessisNevermore Posts: 1,519
    Ron-P wrote: »
    Have you tried: System Settings>Disc Auto-Start?
    I'm pretty sure the Sony will output the audio if it is configured properly even if the monitor is not on. I can't check because I'm 12K miles away from my unit at the moment but run through the menus suggested above..
    Even cheap Sony upconverting DVD changers can do what you're asking....I know, I used to own one that I used briefly to play CDs in the basement...
    cnh
  • Ron-P
    Ron-P Posts: 8,520
    I did set it to auto start when I first bought the player, but I will double check it next time I fire the rig up to make sure it's still set to that. But, I don't remember that fixing the problem.
    I've never been able to play a CD without having to turn the FP on first.
    disneyjoe7 wrote: »
    Eventually. Just don't want to spend the money right now and the longer I wait, the less expensive the players will get.
    If...
  • Conradicles
    Conradicles Posts: 6,339
    Mine plays CD's without the screen on, but I do not use an HDMI receiver.
    That is interesting.
  • Willow
    Willow Posts: 11,229
    Same here, I use Toslink for audio and HDMI for video (I don't have an HDMI AVR yet)
  • Ron-P
    Ron-P Posts: 8,520
    It's only with HDMI.
    If...
  • Willow
    It may not be ideal, but can you not connect a Toslink or stereo to the receiver for music?
  • leroyjr1
    leroyjr1 Posts: 8,785
    I have my ps3 hooked up to my receiver via hdmi and it plays cd's with my monitor off. So it will work just got to figure out how.
  • Ron-P
    Ron-P Posts: 8,520
    Willow wrote: »
    I could, but I shouldn't have to. The entire point behind HDMI is audio and video all in one cable.
    If...
  • Mantas
    Mantas Posts: 9
    leroyjr1 wrote: »
    Same here. PS3 -> HDMI -> Onkyo. The TV does not have to be on.
    I even have my Onkyo receiver setup as a "second monitor" to get sound via HDMI from my computer without having the TV on. (My Onkyo only has 1 HDMI out).
    Onkyo TX-SR806 - Receiver.
    RTi A9 - Fronts.
    CSi5 - Center.
    RTi A3 - Surrounds.
    DSW microPRO 4000 - Subwoofer.
  • mantis
    mantis Posts: 17,339
    Check all your chain settings and turn off all HDMI control. This should do it.
    Dan
  • Ron-P
    Ron-P Posts: 8,520
    Not sure I follow ya Dan.
    If...
  • jon s
    jon s Posts: 905
    it's not the PS3... It's the receiver... HDMI receivers have a config where you can have the HDMI signal pass thru or require a monitor. can't remember exactly where but most receivers have this option and you have to disable or enable it.
  • bevo
    bevo Posts: 306
    Mine also works without the TV on. When I turn off the TV my receiver stops sending the signal for a few seconds but then it comes back and works fine.
    Denon 1909, want to upgrade for pre outs
    Fronts-polk RTi A5
    center-polk CSi A4
    Sides Polk FXi A6
    rears- polk rm8's
    sub-SVS pb-13 ultra
    Blue ray-ps3
    Panasonic plasma 50 inch
    Buttkicker(don't use or need it anymore since getting the Ultra)
