Static Electricity Concern
mufsoman
mufsoman Posts: 632
edited December 2009 in Troubleshooting
I know I need to get my humidifier cranked up now that the colder/dryer weather is upon us, however, I have an alrming amount of static electricity when touching some of my HT equipment. The worst is the PS3. Each time I touch the panel to eject a disc, I get a shock. This happens with some of the other equipment also, but not to the same degree.
I'm concerned about damaging something. Does anyone else have this issue? Is the system not grounded properly to dissapate the charge? Is my Monster PowerBar 1100 not doing its job, either because its faulty or because its just not that good? Any advise will be helpful. Thanks
Parasound HCA-2003A & 2205A
Front: Rti12's
Center: Csi A6
Side surrounds: Polk Rti A1's
Atmos: Mirage Nanosats
APC H15
Power cords by Pepster, Morrow MA4 IC's, AQ Midnight, AQ Chocolate HDMI's[/SIZE]
The rest is TBD.
Post edited by mufsoman on
  • bobman1235
    bobman1235 Posts: 10,822
    edited November 2009
    I would SERIOUSLY hope that consumer electronics will be made to withstand that kind of instantaneous burst, BUT if you wanted to be safe you could just get into the habit of discharging yourself on something benign before touching your equipment.
  • Gaara
    Gaara Posts: 2,415
    bobman1235 wrote: »
    You would be surprised. I got a great deal on a demo Parasound Halo A23 amp once because the matching pre was fried by a static electric shock, no joke.
    I used to have the same light static issues, I got a couple plants and haven't had any issues since.
  • apphd
    apphd Posts: 1,514
    Not sure where you are located, but it seems a little early to be that dry, at least in the NE. Any idea what your relative humidity is? Something like this can be handy to determine if it is a humidty issue or ground/stray voltage issue. http://www.walmart.com/catalog/product.do?product_id=10671021&findingMethod=rr
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    I do not think you are going to harm anything from static unless you are touching the circuit board itself.
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • schnottus
    schnottus Posts: 15
    I don't know about ps3's but most consoles I've taken apart have a nice grounded sheet metal cage that surrounds everything inside to protect against this kind of stuff.
  • gdb
    gdb Posts: 6,012
    I once fried a brand new Lenox micro computer thermostat with the lovely blue spark that came off my fingertip:mad: Static can destroy lots of sensitive electronics (it can also ignite the vapors coming from the fuel opening on your car when you touch the nozzle !:eek:), better to touch the cat or wife to discharge before handling your equipment! A humidifier is a good thing to have also.;)
  • gdb
    gdb Posts: 6,012
    Post #7 Reportage:rolleyes:
  • RuSsMaN
    RuSsMaN Posts: 17,986
    gdb wrote: »
    Roger that, acknowledged and taken care of. (it's actually number 6.xxxx now ;) )
    Cheers,
    Rooster
  • sTiLlLeArNiNg
    sTiLlLeArNiNg Posts: 805
    Strange, i never had any issues with static inside the house, i get a zap nearly every time i get out of a car though. Regardless of time of year :confused:
    Whenever i service my PC i always touch the PSU/case first before anything else....
    Media Room 7.1
    Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
    HTPC
    Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
    A fool and his money are easily parted
    I don't drink Koolaid
    Need some cable's? Just ask :)
  • spapinbri
    spapinbri Posts: 1
    Hi, I need help trouble shooting or fixing my right tweeter. I know the tweeter is out because when I switch speakers with the one that works it still has no upper sound.
    My question is, could the problem be anything other then the tweeter? Cross overs or something else? To be honest I am not sure when the tweeter went out as these speakers still sounds better (with one tweeter) then the speakers the 9's replaced. Where do I order a replacement tweeter?
  • Fongolio
    Fongolio Posts: 3,516
    ^^reported^^
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
