Is One Subwoofer cable just as good as the next?
wesouth
wesouth Posts: 41
I have seen subwoofer cables from 10 dollars to 200 dollars. Will either be just as good?
My Setup:
Front- Polk Monitor 70
Center- Polk CS2
Rear - Polk Monitor 70
Subs - 2 Polk PSW505
Receiver - Onkyo TX-SR707
Amp - Emotiva XPA-5
Zone 2 Speakers - Polk M40
CD Player - Emotiva ERC-1
Interconnects - Emo X-Series
& Emo Ultra speaker cables
additional components:
Television - Samsung LN52B750
Gaming Console - Microsoft XBox 360
Media Center - Gaming Computer with Blue Ray Drive
Post edited by wesouth on
  • mantis
    mantis Posts: 17,558
    edited November 2009
    No not really. The key to a good cable any cable not just a sub cable is proper termination and correct wire used for the job. Once this is achieved and there is no interference then the cable trying to be higher end will make no difference.
    Use quality cables for best results. Like tires you can get cheap ones but do they handle as good in the rain as tires designed to handle in the rain?
    Dan
  • wesouth
    wesouth Posts: 41
    Dynex subwoofer cable used with a PSW505 sub.
    I was wondering if getting a higher grade cable was necessary? what do you think... this is what i have now.
    My Setup:
    Center- Polk CS2
    Amp - Emotiva XPA-5
  • wesouth
    wesouth Posts: 41
    My Setup:
    Center- Polk CS2
    Amp - Emotiva XPA-5
  • kawizx9r
    kawizx9r Posts: 5,150
    I've used Dynex myself, same exact cord you linked there. Picked it up free at bestbuy (bestbuy rewards points), but I found that the AQ Alpha-snake provided tighter bass. I want to say it won't be as important as it would be when choosing IC's between components, but a good/better cable for your sub will make a difference.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • beardog03
    beardog03 Posts: 5,550
    you can find good deals on AQ sub cables at.......www.audioadvisor.com
    no affil
    makes a difference and these are good cables, IMO
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • sk1939
    sk1939 Posts: 295
    I guess it does to a point, like you don't want to have really cheap cables (signal noise/degradation/interference), but there's no real reason to buy $250 cryogenicly frozen exotic cables, especially if they start approaching the price of your components. They don't really add/take away a whole lot, invest more in gear which obviously affects sound alot more.
    P.S. Any type of equipment feet you see advertised as being able to make your music sound better is complete bs and a marketing thing. I personally don't buy the whole cable thing, as most studios in the industry (if not all) use a company relatively unknown to audiophiles, but known to audio professionals called Mogami, which makes the wire for most studios, and no, Mogami wire does not cost $10/foot, and is not cryogenicly treated, although they are braided specially. Alot of studios invest more in audio processing gear than cabling, which shows what they think about cables (something that connects A to B) rather than a whole separate thing unto itself, and budget accordingly.
    Home:
    Onkyo TX-6500MKII/Polk LSI 9's (A)Polk TSi 100(B)/Polk PSW 10/Onkyo C-S5VL/Technics SL-QD33
    Home 2 (Playback):
    Dynaudio BM5A MKII/Dynaudio SUB 250MC/Audigy 2 ZS
    College:
    JBL LSR 2325P/JBL 2310SP/MOTU UltraLite MKIII
