SACD vs. HDCD?
Malaka
Malaka Posts: 39
edited November 2009 in 2 Channel Audio
Many of my HDCD discs sound just as good as SACD! What gives? Am I going deaf, or is this possible?
  • vc69
    vc69 Posts: 2,500
    I have heard some SACD's that sounded like crap. But I have never heard an HDCD that sounded "as good" as a well done SACD. I think there is a tendency among labels releasing HDCD's to take proper care in the entire process. They sound good not because they are HDCD, but because they are well recorded/mastered. Just my opinion really...
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • Norm Apter
    Norm Apter Posts: 1,036
    Wouldn't it depend on whether your player is SACD and / or HDCD compatible? (or are you comparing the hybrid redbook layers of HDCDs vs. SACDs)?
    2 Ch.
    Parasound Halo A23 Amp
    Parasound Halo P3 Preamp
    Parasound Halo T3 Tuner
    Bada HD22SE tube CD Player
    Magnum Dynalab Signal Sleuth
    Magnum Dynalab ST-2 antenna
    polkaudio Lsi9s (upgraded cross-overs)
    MIT Shotgun S-3 Bi-wire Interface Speaker Cables
    MIT Shotgun S-3 Interconnects (3)
    IegO L70530 Power cords (3)
    HT
    Denon 2808ci AVR
    polkaudio RTi A5s (fronts)
    polkaudio RTi A1s (rears)
    polkaudio Csi A6 (center)
    Signal Cable Ultra Speaker Cables
    Signal Cable Analog II Interconnects
    pitdogg2 Posts: 27,914
    vc69 wrote: »
    Well said hit it right on the mark...
    but you need a player that will see the HDCD layer and a Reciever to decode it. My Denon 2900 universal player didn't see the HDCD layer so my Denon 3805 little HDCD light never lit up until i bought a Denon 3910 universal player and finally the little HDCD light lit....:D
    Another one of the music industry's secret...at the very least poorly marketed.
  • vc69
    vc69 Posts: 2,500
    Norm Apter wrote: »
    Yep.
    Norm Apter wrote: »
    Nope
    Windows media player will decode a HDCD too.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
  • Norm Apter
    Agree on HDCD being poorly marketed. When I put CDs in that I've had a while and the green light goes on I'm shocked because I never was aware of the fact that they were HDCDs when I bought them.
    But here is one interesting thing...its my understanding that when you rip and burn SACDs you can not create copies with the SACD layer.
    I bought CDP that is HDCD ready about 6 months ago and it too has a little green light that goes on when it identifies HDCDs. Now, a couple of months ago I put in a burned copy of Phish's Farmhouse, which came in 2000. Though it is a CDR my player recognized it as HDCD. I've never bothered to check whether the original was indeed HDCD, but I'm assuming it is and that my player has not mistakenly identified it as such. Anyway, I thought it was interesting that even CDRs can carry and have recognized the HDCD sound.
    2 Ch.
    HT
    Denon 2808ci AVR
  • vc69
    vc69 Posts: 2,500
    SACD drives are not available for the PC (AFAIK). Not to mention the software required. Hence no ripping and burning. DSD is a proprietary (Sony) format.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
  • Bubinga99
    Bubinga99 Posts: 283
  • vc69
    vc69 Posts: 2,500
    Bubinga99 wrote: »
    Wow. I had NO idea that existed. Has anyone successfully ripped DSD?
    Edit: I see...no ripping, just conversion/creation. Interesting but not relevant in this context. Thanks for the links though!
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
  • danger boy
    danger boy Posts: 15,722
    Malaka wrote: »
    its not possible.
    PolkFest 2012, who's going>?
  • Ern Dog
    Ern Dog Posts: 2,237
    My current and previous cdp were HDCD, so I'm accumulating more HDCD's and love 'em. The Reference Recording label has 90% of their inventory as HDCD titles.
    My favorite classical cd of all time is from them: Rachmaninoff- Symphonic Dances. This hdcd was Grammy nominated 2003 as Best engineered Classical cd. It's a must.
    My next cdp will be an SACD player :)
  • Systems
    Systems Posts: 14,872
    but you need a player that will see the HDCD layer...
    HDCD is an encode/ decode process but there isn't a separate layer for HDCD, its the same data stream as the standard redbook.The difference is that an HDCD compatible player or DAC will have a special digital filter that will unlock (decode) the extra 'bits" of resolution that were encoded in the mastering stage.
    Testing
    Testing
    Testing
  • dudeinaroom
    dudeinaroom Posts: 3,609
    No, it's not hard to believe that HDCD can sound better than SACD. Don't get me wrong I have Boston's Boston on LP, CD and SACD. I do prefer the SACD over the CD(non HDCD as far as I know) But the top end is about in the same ball park as cd, and the LP buries them both from top to bottom.
    Here's a nice little read for you LINK.
  • Cpyder
    Cpyder Posts: 514
    vc69 wrote: »
    I'll agree with this. In most cases it's not the format, but how much care was put into the recording process - and usually more care is put into high-def formats.
    An SACD recording of a 128kpbs mp3 will not sound better because it's SACD.
  • mantis
    mantis Posts: 17,691
    I have a fee HDCD's that sound as good as SACD 2 channel but multichannel SACD is incredible when done right. As good is good but it's not better.
    JVC years ago made XRCD which in my opinion was as good as HDCD and SACD 2 channel. I had a hard time finding any of them in local stores. Online seems to be the only place anymore to buy any higher quality recordings.
    Dan
  • CoolJazz
    CoolJazz Posts: 573
    I agree that the XRCD are really good!!
    A reason that the SACD might not leap out as better is because often the source material they use for it comes from the PCM masters. So you've effectively got them taking a CD kind of quality and dropping it onto the SACD.
    A SACD is going to be at its best when they have a DSD source.
    CoolJazz
    A so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
    More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping."
  • danz1906
    danz1906 Posts: 5,144
    mantis wrote: »
    Agreed 100%
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • BB3
    BB3 Posts: 297
    Thank You Guy's For All Of Your Insight On This Subject. Very Informative.
    Thank You Again.
    BILL(BB3)
    Sony 52in.XBR6
    Sony 32in.XBR6
    Anthem AVM50V
    Anthem PRE-2L
    Sonic Frontiers SFCD-1
    Carver C-9
    Carver C-19 PreAmp
    Carver C-16 PreAmp
    2-Carver Silver 7-T's
    4-Carver TFM55's
    2-Carver TFM35's
    1-Carver TFM25
    Carver 490T
    Denon DCD1560
    Sony BDP-S350
    Sony PS3
    Nintendo Wii
    Panasonic DMK23DVR
    Speakers :
    PolkAudio SDA-SRS
    PolkAudio SDA-SRS 1.2TL
    PolkAudio SDA-CRS+(Compliments Of Mr. Jim Thomas"jtgranby")
    PolkAudio RTA-15TL
    PolkAudio M3
    3-Velodyne F-1500's
  • Systems
    CoolJazz wrote: »
    CoolJazz
    Bingo.
    Testing
    Testing
    Testing
  • dudeinaroom
    SACD is in the high frequency range quite mediocre, even compared to a good CD-system one-bit DAC, and of course clearly inferior to a CD-player with a real multi-bit converter.
    The problem with SACD can be shown by theoretical calculations, measurements and by listening. I have done lots of all these three and every one of them points clearly in the same direction: SACD has not more resolution than CD above 10kHz. Our early estimations some years ago have now been confirmed by measurements and listening, made both by us and others. Today, many studies have been done, for example by Stereophile who has tested SACD players several times and confirmed our estimations.
    the one-bit converters used in CD-players usually have higher resolution than DSD, which only samples 64 times faster than CD-system sample rate (i.e. DSD sampling rate = 2.8 MHz). The low sampling rate in DSD is used because of the systems ineffective coding and lack of storage space. By packing the information it becomes a bit more effective but it still is ineffective compared to PCM.
    One-bit converters for CD-players often use sampling rates between 11 and 50 MHz. The best one-bit converter probably is JVC's PEM-DD and it is much better than DSD. This said with reservation, I might have missed some even better one-bit technology than PEM-DD. But as far as I know this is the technology that comes closest to true multi bit technology in resolution.
    A one-bit converter (i.e. the DSD system) cannot regenerate a short pulse with stringent form. It will change form from moment to moment. Every identical recorded pulse will show up with a new form.
    just some snips from the link I posted above. It is a sacd vs dvd-a but has lots of comparisons to the cd system which is lower res than the hdcd
  • vc69
    vc69 Posts: 2,500
    So dude...
    You posted all that, but it is just a copy and paste from the article you linked?
    Not sure why that was necessary, we are all obviously capable clicking on a link.
    I have a problem with articles that try to convince me that what I'm hearing is clearly wrong because the math doesn't add up. What is your position?
    .02
    I have one release in every disc format (CD - DVD-A - SACD). The SACD format sounds best to my ears and I know for sure that the same mixes (both 2ch and 5.1) were used as masters for the DVD-A and SACD releases (NIN- TDS). It is a title I am intimately familiar with on many systems. The SACD is clearly superior to my ears. I am not certain, but I may be able to pick the SACD out blind. All I know, is that I trust my ears.
    I can believe that inferior DAC could play a big part in why one format, on a given system, could sound inferior. I think if you give each format a fair chance to be it's very best, that differences become rather negligible. But SACD is the best digital format I have bought with 24/96 PCM being almost exactly as good. I believe that the DSD encoding on TDS was done from 24/96 masters.
    /.02
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
    F1nut Posts: 52,406
    Agreed!
    As far as XRCD is concerned, I have noticed that the highs tend to be more forward, which to my ears is not a good thing.
    Comparing the XRCD of BIA to the SACD issue proves to my ears that the SACD is clearly superior with a more natural high end and considerably better bass.
  • dudeinaroom
    Like I stated in my OP I have cd,sacd, and lp of Boston's Boston. The sacd does sound better than the sacd, but not leaps and bounds. I think the real big difference is the sound stage, the sacd wins over the cd, but the cymbals sound more real on the cd than the sacd. I love the way the album sounds, but prefer the convenience of the cd/sacd. Yes F1, I agree the bassis a hell of a lot better on the SACD than the CD. As fas as HDCD goes, I have no clue. I should throw the cd in the computer to see if it is HDCD or not, even if it does this computer lacks the resolution of all of my mid-fi components
