Vista to Mac , anyone have any problems?
mantis
mantis Posts: 17,388
edited November 2009 in The Clubhouse
Whats up all?
A friend of mine just got a brand new mac mini. He was currently using a Vista laptop. He is having problems moving his files to the new mac. Whats going on is he doesn't see it in the Sharing tab on any mac window including finder , iphoto , Itunes etc.
Anyone have any tips? I transferred years ago from XP and it was a breeze. I saw the XP laptop in the sharing tab and away I went.
Thanks in advance,
Dan
Dan
Post edited by mantis on
  • [Deleted User]
    [Deleted User] Posts: 1,394
    Is he using an external hard drive to move the media? If it is NTFS it would not be recognized.
    If he is doing it over the network, then I would not be able to help because I have never tried. The folder on his end of the Vista laptop is set to shared right?
    Halen
  • Fireman32
    Fireman32 Posts: 4,845
    take it to the apple store they do transfers all the time
  • greg2350
    greg2350 Posts: 544
    Mac will not see shared folders on vista but will XP. You have to manually connect to the vista pc by putting in the IP address.
    TV: Philips 42" LCD 1080p
    Front Speakers: Polk Audio RT800i
    Center Speaker: Polk Audio CS1
    Surround Speakers: Polk Audio R50's powered of Denon AVR
    Subwoofer: Polk Audio DSW pro500
    AVR: Denon 3801
    DVD Player: Denon DVM 745 upscale 1080p
    Sat: Directtv HD 10
    Front Speakers Amp: Rotel RB 890
    Center Speaker amp: Rotel 970 BX
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    halenhoang wrote: »
    Halen
    Correct also have is he tying to share them?
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • greg2350
    greg2350 Posts: 544
    halenhoang wrote: »
    NTFS is not the problem I have an external drive formatted NTFS and the mac can read it just fine its a problem with vista try this
    1.With the Finder active, from the Go menu, select Connect to Server... . Alternatively, with the Finder active, press Cmd-k .
    2.In the Connect to Server window that opens, next to the "Address:" field, type the fully qualified domain name (FQDN) or IP address of the vista pc (e.g., idisk.mac.com). Click Connect.
    3.In the authentication window that appears, type your username and password for the vista pc.
    AVR: Denon 3801
    Sat: Directtv HD 10
  • mmadden28
    mmadden28 Posts: 4,283
    Also, on the Vista machine, you have to ensure that File sharing is enabled and also that the firewall is not blocking any of the traffic.
    An actual folder doesn't necessarily have to be shared as you can access the root of the hard drive by mapping to the drive letter and a $ (i.e. \\vistacomputername\c$) as long as you authenticate with an account that had admin rights this should work.
    Or you could just ensure that the root of C: is shared.
    If you have another XP or Vista machine hady see if you can connect to the Visat box that way first to ensure that remote networking is setup correctly at all.
    If the Vista box has any other firewall type software such as McAfee, Symantec, ZoneAlarm, etc, just disable it, do the transfer and then reenable it.
    On the Vista machine press F1, Search for File Sharing and you'll have a ton of things to look at that may help resolve the issue, such as File sharing essentials, etc.
    Alternatively, you can try to see if you can access the Mac from the Vista box, and if so just push the files that way.
    ____________________
    Pool: Atrium 60's/45's
  • wayne3burk
    wayne3burk Posts: 939
    i have a suggestion... he can install boot camp and windows xp on his mac mini (i have mine partitioned and dual boot) -- then can boot up in xp - network with his vista laptop... copy his files to his xp partition... no no -- way too complicated -- i dont know why he cant just write his files to an external hard drive and see that hard drive with his mac?
    never have used vista so i'm speaking out of turn
    Yamaha RX-V2700, EMI 711As (front), RCA K-16 (rear), Magnavox Console (Center & TV Stand), Sony SMP-N200 media streamer, Dual 1249 TT =--- Sharp Aquas 60" LCD tellie
