yet another dumb question.
raidersrule76
raidersrule76 Posts: 471
edited November 2009 in Troubleshooting
I have been moving things around a little bit and I have come across a problem. I noticed that one of my towers and one of my surrounds were not working...I thought that maybe my amp took a ****.:eek: But after futher checking I have come to the idea that it might be my cables. I have Mit avt2 has anyone had a problem with these or similar cables going bad? If so what causes this?
Best regards
Mark
Sig to be updated after dealing with the insurance company:(:(:(
Post edited by raidersrule76 on
  • sTiLlLeArNiNg
    sTiLlLeArNiNg Posts: 805
    Were the connection's tight? I always had trouble with them coming loose for some reason so i switched to banana plug's. Are those cable's the one's with the boxxes on them? Maybe a part inside the box took a vacation?
    Media Room 7.1
    Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
    HTPC
    Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
    A fool and his money are easily parted
    I don't drink Koolaid
    Need some cable's? Just ask :)
