PSW505 Sub problem
Cyberdrew
Cyberdrew Posts: 9
edited November 2009 in Troubleshooting
I recently purchased a PSW505 sub from Newegg to replace my 10 year old Infinity BU-120 12" 100w amp sub. Now I know the infinity sub has horrible reviews on the web, but it had a bit of punch to it and I have had no problems with it except for the woofer cracking at higher volumes.
I was really excited to get this new sub, but once I got it I hooked it up to the sub out on my receiver. I have also hooked it up the Polk recommended way through the main speakers out. Same result, it seems to have a lack of punch. Plus, as I turn the volume up on it, it seems to taper off the louder it goes. I am guessing a bad capacitor? I don't know. It doesn't seem as strong as the junky Infinity I am replacing. I called Polk, their customer service is TOP NOTCH! They are sending me a new amp, I guess we'll see then. Anyone else have an experience like this? I guess what I am looking for is a sub that I can tune to a comfortable bass level for general use, but I want to be able to crank it up from time to time to shake everything to show it off. :D
-Andrew
___________________________________
JVC Receiver RX888VBK
Custom built media center PC
Monitor 60 towers
PS505 sub
46" Samsung LCD TV
NO FRICKIN MONSTER CABLE!
Post edited by Cyberdrew on
  • Cyberdrew
    Cyberdrew Posts: 9
    Well, I got the new amp in the mail today and installed it, it seems to have solved the problem. I really like the sub's deep clean bass but I do miss some of the "punch" my old sub had.
    -Andrew
    Monitor 60 towers
    PS505 sub
    46" Samsung LCD TV
  • kawizx9r
    kawizx9r Posts: 5,150
    Cyberdrew wrote: »
    Give the sub some play time to properly break in, I'll bet it'll sound much better later on!
    Btw, welcome to CP!
    -Freddy
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • Cyberdrew
    Cyberdrew Posts: 9
    What is the best way to break it in? How long to break it in? Pink noise for 5 minutes? Thanks.
    -Andrew
    Monitor 60 towers
    PS505 sub
    46" Samsung LCD TV
  • concealer404
    concealer404 Posts: 7,440
    Cyberdrew wrote: »
    Just play music/movies. Don't beat on it, just normal use. Might take 50-100 hours of use, or less, or more, just depends. You'll hear it change the more it plays.
  • jimmydep
    jimmydep Posts: 1,305
    It took my DSW-PRO 600 about 40 - 60 hours to break-in. I just played music at a normal level.
  • thuffman03
    thuffman03 Posts: 1,325
    Good to hear you got the issue fixed with the sub.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • zeppage2
    zeppage2 Posts: 196
    Customer service cannot be quantified :)
    Props and kudos to the Polk Team!
  • Cyberdrew
    Cyberdrew Posts: 9
    Thanks for all the advice.
    -Andrew
    Monitor 60 towers
    PS505 sub
    46" Samsung LCD TV
  • Cyberdrew
    Cyberdrew Posts: 9
    WOW! I was listening to dance mixes last night at half volume with the sub only at half volume and the crossover at 90hz. This thing really pounds the fillings out of my teeth!!! I am in love and need another one!
    -Andrew
    Monitor 60 towers
    PS505 sub
    46" Samsung LCD TV
  • concealer404
    What are your main speakers?
  • binarycool
    binarycool Posts: 51
    Nice I just ordered one of these off newegg can't wait for it to come in, and perfect timing i just blew out my little PSW350. (Does anyone have any use for it before I just throw it out - I'm in NJ)
    I was complaining about my sound in my new TSi500's a few weeks ago - time has made all the difference. They sound great now. I really never realized how important a break-in period was.
  • Cyberdrew
    Cyberdrew Posts: 9
    My main speakers are Monitor 60s. I replaced a pair of Infinity SM-125s and an Infinity BU-120 sub with these and the PSW505. 100% better sound and performance!
    -Andrew
    Monitor 60 towers
    PS505 sub
    46" Samsung LCD TV
  • Cyberdrew
    Cyberdrew Posts: 9
    My receiver basically is 135wX2 .02% THD, I am just using it for stereo and have the sub hooked up through line outs. I would rather use PRE outs but this receiver doesn't have them, it has a sub out but then it internally crosses over the frequency for the mains and the sub. I hate that. My sound source is a Windows 7 PC using SPIF 48kHz / 24bit connection. (Receiver is 10 years old and wont do anything higher)
    -Andrew
    Monitor 60 towers
    PS505 sub
    46" Samsung LCD TV
  • concealer404
    Cyberdrew wrote: »
    So you have your mains running full range?
    I would actually suggest using the sub out, and setting it on your reciever to 80hz if you could. I think it should sound better.
    Right now you're straining your Monitor 60s to go full range, and probably ending up with a lot of overlap down low.
  • Cyberdrew
    Cyberdrew Posts: 9
    I will try that, but in the Polk manual, it recommended the other setup. Oh yeah, I use a flat EQ with no sound enhancements except I have the loudness turned on.
    I like the sub out option better (less wires)
    -Andrew
    Monitor 60 towers
    PS505 sub
    46" Samsung LCD TV
  • concealer404
    Cyberdrew wrote: »
    Ewww..... turn loudness off. :p
