Tame those metal dome tweeters
  • Systems
    Systems Posts: 14,873
    edited November 2009
    rubin wrote: »
    What type of problems?
    Depends on the material used but one would expect there to be upredictable changes to frequency response and dispersion.
    Testing
    Testing
    Testing
  • Systems
    rubin wrote: »
    So you know about those early speakers.I thought the 100"s would have blown them into outer space.
    Overall the 100's should be a more accurate speaker atleast from the upper midrange on down.
    Testing
    Testing
    Testing
  • rubin
    rubin Posts: 565
    As you all can see I've tried a few things .Nad amps are suppose to be warm,I use a tube pre with mullard tubes.I can"t afford tube amps not even used and I can"t afford speakers either.I have the arcam cd 73 is that a bright or warm player?What a tangled web.
  • Systems
    How do you have them positioned?Are they well away from the walls?Facing straight ahead or toed in?
    Testing
    Testing
    Testing
  • rubin
    rubin Posts: 565
    I think one paradigm problem has is that I heard they have acces to a gov"t sponsered sound/listening room which is engineered way better than what we have at home. So what sounds real good there may not be so good at home.
  • rubin
    rubin Posts: 565
    GV#27 wrote: »
    Straight ahead 4' from the back wall 3' from side walls.Toe in is worse.
  • mmadden28
    mmadden28 Posts: 4,283
    Face wrote: »
    I had a brain ****.
    ... If so, two resistors in series do not sum together, in fact it would lower the circuit's resistance. ...
    I think you had a double brain ****...;) two resistors in series do in fact sum together, it's when they are in parallel the resistance would be lower. With capacitors it's the opposite (they sum in parallel).
    I'm sure you know this already-just don't want anybody else getting the wrong idea.
    ____________________
    Pool: Atrium 60's/45's
  • Systems
    rubin wrote: »
    Like a few other Canadian manufacturers they did utilize the NRC's(National Research Council)anechoic chamber until they had grown to a point were they could afford to build their own.
    rubin wrote: »
    Toe in is worse.
    One would expect it would be.You could try a few degrees of toe out.That then will put the tweeter off axis somewhat and may result in better treble balance.
    Testing
    Testing
    Testing
  • rubin
    rubin Posts: 565
    GV#27 wrote: »
    Toe in-worst , straight-ok , toe out-seems the best for me.Sounds like it cuts the treble and brings out the bass.Just looks a little odd.
  • Systems
    rubin wrote: »
    It would and psychologically be hard to get used to.But if it sounds better you can just close your eyes.
    Testing
    Testing
    Testing
  • Systems
    xcapri79 wrote: »
    Two resistors in series do add together, so that RT = R1 + R2.
    He does a lot of diy xover design and mods so I believe he knows this but was just having a momentary lapse.
    Testing
    Testing
    Testing
  • steveinaz
    steveinaz Posts: 19,545
    Are you listening with the grills on? Ref Studio's are intended to have the grills on.
  • rubin
    rubin Posts: 565
    steveinaz wrote: »
    Both ways depending on my mood,but yes less forward with grills on.I kinda think after using these for 10 years maybe I'm just getting bored with them.
  • Face
    Face Posts: 14,340
    mmadden28 wrote: »
    Crap, you're right. :o Working 70 hours in 5 days fried my brain.
