NO POWER on I-Sonic 2
ernestbanks
ernestbanks Posts: 2
edited November 2009 in Troubleshooting
My I-Sonic 2 has been working fine for the past year. Last week, I unplugged the unit to move it to another room. After plugging it back in, the unit will not power on.
The unit is correctly plugged in, the power outlet is fine. I get no lights, no sound, no power.
Is there a manual reboot process? Or, is there a fuse in the unit that could be blown?
My warranty has expired, and so I'm ok with opening the unit to do a repair.
Thanks.
Post edited by ernestbanks on
  • dubradio
    dubradio Posts: 181
    Ernest,
    If you look at the inline power transformer for the IES2 do you see a small green LED when it is plugged in?, if not you may have a transformer that has gone out.
    -Kyle
  • ernestbanks
    Thanks Kyle. You were correct. When I plug it in, the green LED is not lighting. Must be a bad power transformer. Can I buy a generic replacement, or does Polk sell replacements? I assume a new transformer is pretty inexpensive.
    Thanks for your help!
  • dubradio
    dubradio Posts: 181
    Ernest,
    Replacement Power supplies can be purchased directly from Polk Audio @ 1-800-377-7655 mon-fri 9am-5:30pm EST.
    -Kyle
