Whats the best HT processors on the market
buymesome
List only processors that you know of and not receivers
Post edited by buymesome on
theres a ton out there,
Outlaw Audio, Anthem, Onkyo,Adcom, Lexicon, Cary, Krell, Classe, and more. The question is what can you afford. Makes no sense to mention a 3k Anthem Pre if you can't spend the cash my friend. Bang for buck would be Outlaw Audio.Shoot the jumper.....................BALLIN.............!!!!!
The anthem d2 with arc is a fine one as well as the krell at $18000 but the threads more about whats out there for reading up on . I can afford any of them but would mess with my savings
i should have mentioned . Whats the best HT processors that have HDMI audio?
Does the outlaw? -
When you say HDMI do you mean 1.3 to process HD audio? I think those are limited. But since 3k for one is out of my budget, like Sherardp said I don't bother looking at the Krells and Anthems so maybe there are more than I think.
The Onkyo Integra DTC-9.8 has gotten some very nice reviews and is pretty much loaded with features for its fairly accessible price!)
I would wait to see a hands on review but check out the Emotiva UMC-1
The reason to wait is they had issues with previous HT pre-pro's that left egg on their face. They most likely learned their lesson though. We will see.
My only real issue: No headphone jacK? -
Outlaw has a new processor that was first announced last year. It has still not seen the light of day, but it seems to be another 3-4 months away. When it comes out - it is what i am planning to get. (barring a bunch of negative reviews) For now, it is just vaporware though.
It is supposed to support all the new codec's.
Michael
Any idea on the price bud?
processors with hdmi 1.1 should be included . Ijust saw a rotel 1069 on the gon for 900 and you could run a hdmi splitter so the rotel only handles audio because it cant do 1080/24 fps . Anyone know if this does good 2 channel? -
Michael
I don't know if I'd even touch that at this point. It would have to get some stellar reviews.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
cnh
That is the one I would probably buy if I were in the market for one. The Anthem D2v would be nice but alas, a bit out of reach.-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
Muscial Fidelity M1 DAC
VTL 2.5
McIntosh 2205 (refurbed)
B&W 801's
Transparent IC's -
I have the Integra 9.9 and it's very nice.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
wingnut4772 wrote: »I have the Integra 9.9 and it's very nice.
is there a huge difference with the 9.9 as opposed to using a 1.3 receiver as a prepro when it comes to bluray audio? -
Here are some:
in no particular order:
They are all hdmi 1.3 enabled, some are not out yet.
Rotel RSP-1570
sunfire TGP-401
B&K reference 70
Maranz AV8003
outlaw Model 997
Emotiva UMC-1
integra DHC-9.9Current HT setup
Mains: B&W 804s
Center: Polk CSi5
Surround: Polk FXi3
Sub: Velodyne DLS-3750R
Receiver: Pioneer SC-07
Amplifier: Sunfire TGA5200
TV: Sony KDS60A2020
DBP: Sony DBP-S350
CDP: Pioneer DV-48AV
Interconnect cables: SignalCable analog II
speaker cables: SignalCable Ultra Speaker Cables Bi-wire -
Who did not see that one coming:rolleyes:...
It is my understanding that Emo has used Sunfire as the donor for it's previous attempts at a pre/pro. I wish them well with it.:)The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
“When once a Republic is corrupted, there is no possibility of remedying any of the growing evils but by removing the corruption and restoring its lost principles; every other correction is either useless or a new evil.”— Thomas Jefferson -
$1,399.
Here is a cut and paste of its expected feature set:
Main Features
HDMI 1.3 with Deep color support
Lossless Audio: Dolby TruHD; DTS Master Audio
Dolby Digital EX, Dolby Pro Logic IIx fully adjustable, Dolby Virtual Speaker, Dolby Headphone Layers 1, 2, 3
DTS-ES Discrete and Matrix, DTS-96/24, DTS NEO-6
Analog to Digital Video Transcoding
Silicon Optix Reon scales all video up to 1080P
XM Radio "Connect and Play" w/ Neural Surround
Bi-Directional USB/RS-232
Upgradeable Firmware
Multi-room/Multi-Source Capable
Advanced GUI On-Screen Display
7.1 Multi-channel Analog Input
OSD over HDMI
A/V LipSync Delay per Input (0-200mS)
Audio/Video Features
Dual TI 32-bit DSP processors
Quadruple Crossover
Surround Preout Reassignement (Bi-amp)
4 HDMI inputs, 1 Output
Theater Compensation
Balanced Audio Outputs
Trinnov Optimizer
Includes 4 Microphone Capsule Acoustic Probe
FIR and IIR filters to flatten speaker response
Loudspeaker (RE)Mapping
Supports ITU Surround Music and SMTPE Cinema Standards
Before/After Curves availble to USB output for Analysis
Additional Features
High performance tuner
Direct access station tuning via remote control
30 Station Presets
Room 2 A/V Output with fixed/variable audio level, S-Video and coaxial digital
IR control with 2 inputs and 1 output
Dedicated Room 2 Remote
Front Panel A/V and Mike Input
Video Input Renaming
Channel Level Memory
12-volt Trigger
Aluminum Front PanelMains.............Polk LSi15 (Cherry)
Emo has been going on about the umc1 for too long and I think they should have kept it hush until they were ready to release it or a couple of months before . Instead they look like idiots or amateurs by all the utter **** regarding a release date its so unnecessary the way they have gave false hope to there loyal customers
Regardless I'm still very curious about it and this may just be the dark horse in HT -
Problem is they will most likely release it with bugs since it has been stalled and they missed the window. Better hope it has the ability to have F/W downloaded.Speakers: SDA-1C (most all the goodies)
For me this comes down to Audessey with height channels vs. Trinnov. Waiting on the Outlaw 997 to see how this pans out.My Iron Man training/charity blog.
HT:
32" Sharp LCD. H/K dpr 1001 to Outlaw Audio 7900 to Polk LSi + Paradigm Studio center. Hsu DualDrive ULS-15. PS3/Wii. Outlaw 7900. -
By the time it comes out the features will be outdated as a matter of fact I think they are already outdated. People have been waiting for this golden cow for a long time and it still hasn't made a debut.I would wait to see a hands on review but check out the Emotiva UMC-1
The best dollar for Dollar processor is the Integra DHC 9.9. It simply can't be beat.
The Anthem D2v2 is very good but it cost 7600.00. There are a lot of things you can do with that kind of money.
There are a lot of processors out there right now but I'm sorry to say none of which I would spend my money on except the Integra. NAD's offerings are looking good but I'm still waiting to Install a few more. Forget about B&K , Rotel there preamps leave a lot to be desired. Waste if you ask me. Really no one is doing it right right now. Stick with the Integra , it's the one and only one.Dan
Michael
X2 on outlawHT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
For HT, I've been a fan of Outlaw. Good stuff, good prices...good CS. I wouldn't really worry too much about getting stuck with a lemon.
Anthem D2 does it all!Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
If comparisons are for brand new... is not the Integra 80.1 (at list of $2,300) now available and should be in the mix? From what I have read, they're ahead on the curve improving on the already impressive 9.9. Anyone have any hands on yet?Pioneer Elite Kuro 50" Pro111FD
Front: Polk LSi15
Center: Polk LSiC
Surround: Polk LSiF/X
Sub: Polk PSW10
Amps: Rotel RB 993 &
Parasound HCA-800 II
Pre/Pro:Anthem AVM-20 -
I know the OP said no receivers, but I would think a Pioneer Elite SC-09 would be simply kick a$$ standing duty as a Pre. Talk about a gorgeous piece of equipment. One could only wish Pio Elite had such offering.Shoot the jumper.....................BALLIN.............!!!!!
Integra DHC-9.9. That's mine and it just smokes some serious **** for HT. Not to mention the price for what you get is just steller, just get one and don't look back (you wont have to).
Dave
