Best connection method for original Xbox?
comfortablycurt
comfortablycurt Posts: 6,745
edited November 2009 in Video Games
Hey everyone.
I just recently dug out my original Xbox. I haven't played it in quite a while, so I figured I'd hook it up. The cables I've got for them are just standard composite video/stereo RCA cables.
Is there much of a benefit to be had by hooking the audio up with an optical cable? I can't take advantage of HD video quite yet, because my TV's from the stone age.
I was looking at this one...
http://www.amazon.com/gp/product/B000AMKYV8/ref=s9_simz_gw_s0_p63_i1?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-2&pf_rd_r=0K1GC54HZ1S2ED6CRXVM&pf_rd_t=101&pf_rd_p=470938631&pf_rd_i=507846
Should I pick one up, or is it not worth it?
Is there a better cable I should look at? I see that Monster has an optical cable for Xbox...
The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
Post edited by comfortablycurt on
  • mantis
    mantis Posts: 17,570
    If your tv has component , yes buy the cables. If you have a surround system with optical in , yes buy the cables. This is the best way to use the Xbox. It's a good machine when it works. It sounds and looks good. When I used mine I felt the 360 was really not needed.
    I still have mine underneath my bed. I whip it out once in a while. As far as Monster or others, they all perform about the same so whatever you can get a good deal on is fine. Monster game cable are built very well.
    Dan
  • buymesome
    buymesome Posts: 281
    I bought a monoprice cable with the fancy connect and it keeps slipping out but same boat . I have the original xb360 and try'd it with L/R through the onkyo607 and it really sucked for highdef movies and mp3 then bought the optic cable and there is a 70% improvement for sure
    Movies ,games and mp3 sound great
  • tommyboy
    tommyboy Posts: 1,414
    Hey everyone.
    def hook up using optical as the xbox ( with exception to few very old games) are dolby digital. Now what quality of cable you use will always be up for debate ;)
    AVR: H/K AVR240
    Fronts: Monitor 50s
    Center: CSI3
    surrounds: R15s
    Sub:Velodyne DPS10
    Dvd/Cd: Samsung HD upconverter (for now)
    TV: 50" Sammy Plasma
    game hardware: 360 and gcn.
    Gamertag: kovster27
  • comfortablycurt
    Thanks for the advice.
    My TV currently only has a composite input, so I won't need the component video cables yet, but it'll be nice to have them when I upgrade the TV.
    I'll go ahead and grab one of these cables sometime soon.
