no sound from a9 tweeter
superjunior
superjunior Posts: 1,632
edited November 2009 in Troubleshooting
a couple weeks ago I noticed there was no sound coming from the tweeter in one of my rtia9s. I switched speeker outputs,ect.. to be sure the problem is in the speeker and not the wiring or gear. Its definatly the speeker. So I figured I must have blown the tweeter and ordered a new one from polk. I installed it yesterday and still no sound :( Well now I've got a spare a9 tweeter but can someone please tell me where to look next? any help is MUCH appreciated. thanks
Dan
panasonic th-50pz85u
pioneer elite vsx-92txh
pioneer elite bdp-05fd
emotiva xpa-3
monster power hdp 2550
sa 8300 hd dvr
sda 2b's
fronts - rti a9's
center - csi a6
surrounds - fxi a6's
sub - polk dsw pro 600
harmony one
Post edited by superjunior on
  • kawizx9r
    kawizx9r Posts: 5,150
    Are the jumper posts (ones that connect the top/bottom sets of terminals when you're not bi-amping/etc.) sitting tightly between the terminals?
    Maybe a loose solder or something came disconnected within the cabinet from your x-over.
    I won't say test the tweeter since you've already found the culprit, but if you want test the original tweeter at a low volume connected straight to your receiver to make sure it's working fine. If you replace a tweeter/driver it's best to replace them on both speakers to let them break in at the same time.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • superjunior
    kawizx9r wrote: »
    thanks Fred, I checked the jumper plate and posts, they're all tight . I would guess its not the tweeter itself but something within the speeker as they did arrive a little banged up from shipping. I'll probably put the old tweeter back in to keep things the same in both speekers. How do I access the x-over?
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • kawizx9r
    I will assume the x-over is near the speaker terminals so you would either be required to take out the lowest mounted driver (for larger opening) or the speaker terminal plate on the back. Hopefully it's something minor that you can just re-solder or connect, but it's best to check there since your new tweeter wouldn't work when you plugged it right in.
    Edit: Iirc, I thought I read somewhere about the crazy design they have for the RTiA enclosures so it's probably best you try to get to your x-over from the rear.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • superjunior
    anyone else dug into an a9 before?
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • leroyjr1
    leroyjr1 Posts: 8,785
    Take the four screws out on the speaker terminal (rear) to access the crossover. The crossover is built right on the terminal plate.
  • superjunior
    I guess todays project will start with the crossover and go from there - after raking the leaves in yard :mad: - I'll post my findings later. thanks fellas
    Dan
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • superjunior
    I can't get the crossover out far enough to see anything. do I have to disconnect any or all drivers to get more slack to the x-over? is it just the wires going to the drivers that keeps it from only coming out maybe an inch? I've never taken a speeker apart before :confused:
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • superjunior
    from what I can see the solder from the tweeter wire on the x-over looks solid. I'm at a loss here...:(
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • gtu2004
    gtu2004 Posts: 620
    check to see if any resistor has fell off, come losse, or burned.
    My LsiC tweeter was not working and when I opened it up, I saw one resistor was sticking to the cabinet. I bought it used from a member on here, and I don't know how it got there.Good thing it was still functional so after I solder it back to the crossover, the speaker worked fine.
    Onkyo 805, RtiA5s, Csi5, Rti6s
  • superjunior
    gtu2004 wrote: »
    far as I could see, and I couldn't get a real close look as the x-over only came out of the speeker about an inch or so, exposing only 1 side, everything seemed to be in order. I removed the middle driver to get a look at the back of the x-over and I couln't get a great look but nothing seemed to be loose or burnt. might have to take it in to some sort of speeker or electronics repair place. very depressing..:(
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • kawizx9r
    If you can get a multimeter, can't you check to see if you have anything come out from the wires that go to the tweeter off the crossover?
    See if you can check while listening to music if there's any output. Sucks that you can only see the x-o so much.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • superjunior
    kawizx9r wrote: »
    thanks Fred I'll pick up a multimeter and give it a shot. there's a plug that the mids and tweet wires go through in the upper chamber and they are a very tight fit through there limiting any slack to the x-over.
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • sTiLlLeArNiNg
    sTiLlLeArNiNg Posts: 805
    Using a DVOM with an audible continuity signal (a beep sound lol) you should be able to find the problem quite easily, just set the DVOM to the setting that look's like this: .))) and check each lead, resistor, coil, cap whatever! No beep = no good :)
    Media Room 7.1
    Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
    HTPC
    Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
    A fool and his money are easily parted
    I don't drink Koolaid
    Need some cable's? Just ask :)
  • superjunior
    I'll give it a shot but again access to the x-over is so limited you can barely even get a visual on the whole thing
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • sTiLlLeArNiNg
    Have you tried to disconnect the lead's from the driver's to give you more slack? I would think if you pulled the lead's off of the tweet it would allow you enough slack to pull the X-over out more :o
    Media Room 7.1
    HTPC
  • superjunior
    the wires from the mids and tweet go through some type of plug in the upper chamber maybe to keep it air tight? who knows how polk even got those wires through that plug but they wont budge. you can't fit your hand in there either. the plug would have to be pushed out towards the back of the speeker to get slack to the x-o, which it would seem impossible to ever get that plug back in place
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • Jed Leland
    Jed Leland Posts: 183
    Hello Dan,
    I believe Polk uses a gummy kind of material to plug the hole where the upper connecting wires go through the sub-enclosure. If you remove the tweeter, drivers and woofers from the cabinet you'll be able to remove the crossover completely. I'm going to assume you have tried the replacement tweeter in the other working speaker to make sure it is not a defective tweeter. If so, then the crossover is the only other part of the speaker that could be the cause.
    Cheers, Ken
    Toolfan66 Posts: 18,011
    Also if you wanted you can label all wires with masking tape or painters tape so you can put them back where you pulled them from. if this is a concern for you.
  • sTiLlLeArNiNg
    superjunior try and give Polk CS a call, they are VERY friendly and ALWAY's willing to help ;) You can use tape to "mark" the wire's or just snap a pic with your camera phone (what i do lol) Sorry can't be of more help :o
    Media Room 7.1
    HTPC
  • superjunior
    just talked to polk cs and they said that plug is indeed a gummy type material that can be coaxed out, with a little carefull effort. since I know very little about caps, resistors, soldering ect, I figure I'd ask how much for a new x-o. 75.00 - without my club discount, so probably closer to 60somthing, and it has all the driver wires attached and ready to plug in. Think this is the route I'll go unless someone has a better suggestion. thanks everyone that chimed in - always appreciated!
    Dan
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • Jed Leland
    Hello Dan,
    That sounds like the best plan, assuming you've checked to make sure the tweeter you were sent was operating correctly.
    Regards, Ken
  • superjunior
    ordering a new x-o from polk this weekend, it will likely be a week or two before I actually get the time to do the work though. good thing I got my little sda's to keep things up and running in the meantime. would it be a good idea to replace those driver gaskets since I'll have them all pulled off anyway?
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
