Pa 1200.1
Vertigo107
I have a new 1200.1 amp and it seems to work fine, but I noticed that the power light stays yellow during operation. This happens if the sub is hooked or if it isn't; same with RCA cables. The other 2 amps are fine. I've checked and recheck all connections, but it stays yellow. The only time it's green is when I turn the system off. Then it stays green as the power leaves the amp, about 10 seconds maybe? Has anyone ever had this happen? Thanks.
CJ
Post edited by Vertigo107 on
My recommendation would be to take this question to the car audio section of these forums for a better response. Good Luck!HOME AUDIO:
Electronics:
HK 354
Front Power: CARVER TFM-35
Center Power: Audiosource Amp One
Speakers:
Center: CSi5
Fronts: rti10s
Rears: monitor 50s
psw 125 + psw 505 = BOOM
CAR AUDIO
Infinity 6032CF's all around
