Are my FXi A4's toast??
RCFGuitars
RCFGuitars Posts: 159
edited October 2009 in Troubleshooting
There's a lengthy back story to this, but I'm too p.o.'d right now to go into it. The short version: I got my Adcom back from a service facility, hooked it back up, turned it on, and "pop", it looks like it instantly blew a fuse, and some ugly noises came from the sides. No sound coming from the centers, and very low levels from the A4's. I immediately switched it off. I plugged my centers and sides into my AVR to test, and the centers sound fine, but the A4's are only producing a weak/thin sound from the tweets, and nothing from the bass/mid driver.
My question: Does the FXi A4 have a fuse that can be replaced or reset, or are they history? The Adcom repair is under warranty, but I'm trying to figure out if there is a quick fix for the speakers, or if I need to pull them down and take them back to the shop also.
Primary System
Polk Audio SDA SRS 2.3TL (RDO198,Sonicap/Dayton/Mills,CardasCCGR,Mye Spikes,DynamatX,Driver Rings,Ben's IC,Bi-Wired)
Polk Audio CSiA4 x2 (C)
Polk Audio FXiA6 (S)
Polk Audio RTiA3 (RS)
Polk Audio FXiA4 (FX)
Epik Sentinel x2
Yamaha RX-V3900
Rotel RB-1090
Rotel RMB-1095
NAD C565 BEE
Technics/KAB SL-1210M5G w/ Denon DL-160
Parasound Halo P7
OPPO BDP-83
Panasonic TC-P65V10 65" Plasma
Post edited by RCFGuitars on
  • sTiLlLeArNiNg
    sTiLlLeArNiNg Posts: 805
    edited October 2009
    AFAIK there is no fuse, i think who ever serviced your amp did a boo-boo and you may have to chase them for replacement's :o
    Media Room 7.1
    Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
    HTPC
    Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
    A fool and his money are easily parted
    I don't drink Koolaid
    Need some cable's? Just ask :)
  • RCFGuitars
    edited October 2009
    That's what I was afraid of, I just wanted to make sure I wasn't overlooking the obvious before I go back and chew them a new one. I've been working on this system since August, and this was the last link. When I plugged it all in last night, and it went bang in the first millisecond, I nearly lost it.:mad:
    Primary System
    Epik Sentinel x2
    Yamaha RX-V3900
    Rotel RB-1090
    Rotel RMB-1095
    NAD C565 BEE
    Parasound Halo P7
    OPPO BDP-83
  • ilsouba
    ilsouba Posts: 1
    edited October 2009
    RCFGuitars wrote: »
    Okay, I have figured it out:-)
