Mike's Emerald Physics CS2.3 System
SolidSqual
SolidSqual Posts: 5,218
edited August 2010 in 2 Channel Audio
Hey Guys,
Some pics of my new speakers are well over do. Frankly, this thread is tardy because I've been spending all my time either working or listening to tunes.
These speakers sound utterly terrible out of the box, which was the case more or less with the CS2s, but even worse here. However, after 24 hours, the compression driver really started to open up. I got 300 hours on them now and can honestly say the sound is leaps and bounds better than my old CS2 setup.
The current pics only display my digital setup. I'll have some new ones eventually once I have my analog gear presentable.
Enjoy,
Mike
376_172_big.jpg?rand=677618088
376_173_big.jpg?rand=628287864
376_174_big.jpg?rand=734190675
376_176_big.jpg?rand=854175313
376_177_big.jpg?rand=65104825
376_178_big.jpg?rand=157224069
376_179_big.jpg?rand=177319588
376_180_big.jpg?rand=899298662
376_181_big.jpg?rand=422246539
376_182_big.jpg?rand=644764844
Post edited by SolidSqual on
  • jimmydep
    jimmydep Posts: 1,305
    edited October 2009
    Mike, those are pretty speakers.......But just a dumb question, where are the tweeters?
    I'm assuming the top speaker is a coaxial.....
    Jimmy
  • SolidSqual
    edited October 2009
    The tweet screws into the back of the 12 inch woofer.
  • danz1906
    danz1906 Posts: 5,144
    edited October 2009
    Very nice speakers!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • Systems
    Systems Posts: 14,872
    edited October 2009
    These are fully active are they not?I ask because in one pic I see an elelecrolytic cap (and possibly some other components) so I assume these must be for contouring or impedance eq ?
    Testing
    Testing
    Testing
  • unc2701
    unc2701 Posts: 3,587
    edited October 2009
    IIRC, It's biamped- the top end has a passive crossover between two coaxial drivers, then there's an active crossover splitting the coaxial and those 15's. Plus the 15's are EQ'd to boost the IB rolloff.
    PS, those might have knocked off the DQ-10's for the ugliest naked speakers.
    Backburner:Krell KAV-300i
  • Systems
    edited October 2009
    unc2701 wrote: »
    Ah Ok thanks that makes sense,but hopefully that "lytic" isn't in the hi pass network:eek::
    I would think that would be done electronically,likely in the DBX unit listed?
    Yep the DQ10's nude were some ugly.
    Testing
    Testing
    Testing
  • unc2701
    edited October 2009
    GV#27 wrote: »
    I would think that would be done electronically,likely the DBX unit in his rig list.e
    Sorry, wasn't clear- the EQ & bottom-end crossover are _both_ active & done by the DBX.
    Huh- I thought they were shipping those with the DCX2496, not the DBX. Solid must have upgraded.
  • BlueFox
    BlueFox Posts: 15,250
    edited October 2009
    Is this the setup your girlfiriend's friends were playing with?
    Interesting speaker design. Does the individual speaker size eliminate the need for a boxed enclosure?
  • Systems
    edited October 2009
    unc2701 wrote: »
    The Behringer is a wonderful and versatile tool for DIYer's but I'm unfamiliar with the DBX unit.
    Testing
    Testing
    Testing
  • Systems
    edited October 2009
    BlueFox wrote: »
    The thinking is that by removing the box you remove it's associated resonances and colourations.However doing so results in reduced low frequency efficiency,extension and output capability.The use of multiple big drivers and specalized eq will allow for much of it to be gained back.
    Testing
    Testing
    Testing
  • unc2701
    edited October 2009
    GV#27 wrote: »
    Yeah, the dcx is a hell of a lot easier than prototyping crossovers... The DBx is pretty close- played with one briefly. More expensive, tho.
  • SolidSqual
    edited October 2009
    I got the dbx 260 coming back my way here soon. Clayton is doing some final updates to the programming. Those pics are of my modded Behringer.
  • SolidSqual
    edited October 2009
    Yeah, the speakers are pretty ugly naked, but I think they'd be pretty sweet with the wood finish and holes large enough to display the drivers. I may make some panels to test this theory.
  • Conradicles
    Conradicles Posts: 6,391
    edited October 2009
    I think they are beautiful naked. O.K...that sounded like something I told many old girlfriends.
    F1nut Posts: 52,087
    edited October 2009
    Nice looking rig Mike. What's the reason for the small openings with the front panels in place and can you notice a difference with the panels on/off?
  • SolidSqual
    edited October 2009
    I'm not sure why the small openings are there, but I will be putting together some questions like this to ask Clayton. The bass decreased when I took the panels off and also lost some accuracy. So evidently they are more than just an aesthetic function. Actually, I think maybe some of the bass is reflected to the rear of the speaker and subsequently loads the room . . . not sure really. It's a bizarre effect when you remove and replace the panel.
    And, yes, this is the system my girlfriend's friends were effing with.
  • unc2701
    edited October 2009
    SolidSqual wrote: »
    I'll try to find the link, but Martin King did some research on different panel configurations with OB speakers. Basically you can manipulate the frontwave/rearwave cancellation quite a bit by changing the shape of the baffle.
    So my guess is that the openings make the frontwave bass more directional thus reducing the cancellation. The grills don't look tight enough to create a loaded chamber between the the driver and the grill, but I could be wrong.
    So you got updated progs for the Behringer, too? I'd be curious to hear your thoughts on that vs the DBX.
  • Face
    Face Posts: 14,340
    edited October 2009
    Here's some good reading on open baffle and dipole speakers. http://www.musicanddesign.com/
    System looks great Mike. The DBX is supposed to be the bee's knees(and should be for the price).
  • Ern Dog
    Ern Dog Posts: 2,237
    edited October 2009
    Mike- This looks like a nice high-end setup. Those bass drivers are huge! No need for a sub. When can we come over?
  • Jim Shearer
    Jim Shearer Posts: 369
    edited October 2009
    For those interested in a discussion of open baffle (OB) design, Martin King's web site is: www.quarter-wave.com
    There is life outside the box!
    A day without music is like a day without food.
    edited October 2009
    Looks nice....though not my cup of tea,but I have the same question about the small holes infront. Seems more restrictive. Maybe they wanted to force the sound through it.
  • BB3
    BB3 Posts: 297
    edited October 2009
    Jesus Mike ! What A Neat Looking Setup You've Got There. You Must Be Very Proud.
    If You Don't Mind Me Asking.....What Type Of Audio Racks Are Those ? I Absolutely Love The Way They Look.
    Other Than That Mike, Take Care Of Yourself And Happy Listening.
    Bill(BB3)
    Sony 52in.XBR6
    Sony 32in.XBR6
    Anthem AVM50V
    Anthem PRE-2L
    Sonic Frontiers SFCD-1
    Carver C-9
    Carver C-19 PreAmp
    Carver C-16 PreAmp
    2-Carver Silver 7-T's
    4-Carver TFM55's
    2-Carver TFM35's
    1-Carver TFM25
    Carver 490T
    Denon DCD1560
    Sony BDP-S350
    Sony PS3
    Nintendo Wii
    Panasonic DMK23DVR
    Speakers :
    PolkAudio SDA-SRS
    PolkAudio SDA-SRS 1.2TL
    PolkAudio SDA-CRS+(Compliments Of Mr. Jim Thomas"jtgranby")
    PolkAudio RTA-15TL
    PolkAudio M3
    3-Velodyne F-1500's
  • sTiLlLeArNiNg
    sTiLlLeArNiNg Posts: 805
    edited October 2009
    Odd/interesting looking speaker's but VERY nice setup! :)
    In case i missed it what are you using for amplification?
    Media Room 7.1
    Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
    HTPC
    Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
    A fool and his money are easily parted
    I don't drink Koolaid
    Need some cable's? Just ask :)
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited October 2009
    BB3 wrote: »
    Bill(BB3)
    Those are VTI racks...The BL series to be specific.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • SolidSqual
    edited October 2009
    I have two Wyred4Sound Stereo Amps, one for each speaker. Each amp has two independent D-class amps within. I got 500 watts for the subs and 250 watts for the mids and highs.
  • kevon27
    kevon27 Posts: 18
    edited October 2009
    Please excuse my ignorance. But how can those speakers produced any bass without it being in a enclosure?
  • kevon27
    kevon27 Posts: 18
    edited October 2009
    Second question.. How can you have a horn/tweeter driver stuck inside of a woofer magnet? Can does speaker produce any sort of high range sounds?
    Dude, you are confusing me... Please explain (for the uneducated) how your speaker works.
    thanks
  • Jim Shearer
    edited October 2009
    kevon27 wrote: »
    As I said before, read:
    Look under OB theory and under Projects (Lowther OB)
    And if you want to try a simpler and WAY cheaper OB speaker, try building the passive OB Martin discusses. (The Em Phy uses an active XO and major EQ.) I built a version of the passive OB speaker using the Eminence Alpha 15a and Fostex FF85k. Photo below shows the OB with an FE108eSigma Metronome to its right and an F120A Metronome behind it. Read about in a major OB thread on DIYaudio.com . My build is described starting on page 48, reply #479. link:
    http://www.diyaudio.com/forums/full-range/108751-new-mjk-baffle-article-48.html
    If you like Magnaplanar and electrostatic speakers, you will probably enjoy OB.
    Warning: Speaker building is addictive!!
    Cheers, Jim
  • BB3
    BB3 Posts: 297
    edited October 2009
    Thank you Mike for getting back to me on this. I really appreciate it.---Bill(BB3)
    Sony 52in.XBR6
    Sony 32in.XBR6
    Anthem AVM50V
    Anthem PRE-2L
    Carver C-9
    Carver C-19 PreAmp
    Carver C-16 PreAmp
    4-Carver TFM55's
    2-Carver TFM35's
    1-Carver TFM25
    Carver 490T
    Denon DCD1560
    Sony BDP-S350
    Sony PS3
    Nintendo Wii
    Panasonic DMK23DVR
    Speakers :
    PolkAudio SDA-SRS
    PolkAudio RTA-15TL
    PolkAudio M3
    3-Velodyne F-1500's
  • SolidSqual
    edited October 2009
    Racksandstands.com has good deals on the VTI stuff.
