Old Computer speaker driver
ilovebeingmommy
I have some older polk audio speakers for my computer. They worked fine until I had a virus and had to have it removed. Now The computer says that I have no audio output. I'm thinking I need a driver for this...but have been unable to locate one. It says Polk Audio MM-10...if anyone can help...it'd be appreciated.
Post edited by ilovebeingmommy on
The speakers wouldnt need a driver. It would be your audio card that would need the drivers. You have onboard sound? Seperate sound card? What OS are you running... etc...
PaulyLife without music would♭ -
^^^ Correct go to your computer manufacture website and get the audio drivers. Or the manufacture of your audio card.HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
Paulybigaudiofanatic wrote: »^^^ Correct go to your computer manufacture website and get the audio drivers. Or the manufacture of your audio card.
+1
To everything said above. WITH that I'd also recommend checking all your other drivers IE motherboard/video card/onboard video/etc. If a driver becomes incompatible with said-hardware just rollback
Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
If your running windows, then run windows update, and check the 'optional' updates as well. You might see the driver for your system under 'hardware updates'.I refuse to argue with idiots, because people can't tell the DIFFERENCE!
I am using a 10 year old HP Pavilion 500w series computer. I lost my speaker icon files during a system recovery. Contacted HP and they said it was an ongoing problem that hasn't been fixed. I am looking for the sndvol file driver software here on the website. I hope I find it.
