how to remove a plastic cap from inside an RTI A9
madnod
madnod Posts: 79
edited October 2009 in Troubleshooting
this is little embarassing!
i was just installing my new RTI A9 and when removing the connector plastic cover (to remove the central plastic cap) in order to use banana plugs, the red cover felt into the lower cavity within the speaker, the speaker is too big to wiggle, how i can have an access in order to remove it from the inside of the speaker? i am affraid that it starts ruttling inside.
thanks!
Post edited by madnod on
  • jimmydep
    jimmydep Posts: 1,305
    edited October 2009
    How about a vacuum cleaner. If its too far in get a small diameter hose and tape it to the end of the nozzle, feed it into the port and Walla.........or remove one of the drivers and stick your hand in.
    Welcome to Club Polk
    Jimmy
  • madnod
    madnod Posts: 79
    edited October 2009
    thanks for the vaccum tip.
    i unscrewed the front vent and after sometime i was able to suck the cap.
    thanks again, simple and effective.
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited October 2009
    Just leave it.
  • jimmydep
    edited October 2009
    My Pleasure.....
    F1nut Posts: 50,734
    edited October 2009
    What is ruttling?
    tonyb Posts: 33,000
    edited October 2009
    What is ruttling?
    Baby pot holes,silly.
