Surroundbar SDA setup issues
bandito
bandito Posts: 1
edited September 2009 in Troubleshooting
Thanks Justin for the forum rules.
I am having some big issues in getting a Surrond Bar SDA properly set up.
My subwoofer sees the channel of the base unit, but its green light flashes, and occasionally only makes huge static sounds. I have tried all four channels on both, same problem.
My base unit is now flashing a green light also, yet operates on its own fine.
Trouble getting the Panasonic Mute and Volume buttons programmed despite resetting all many times. Panasonic 54 HDTV V series.
Sub Woofer makes big static blasts that are unpredictable. It operated once for me for about 20 minutes a few days ago. Not since.
Hardware problem, or programming error by owner and poster?
Thanks in advance for your assistance! I look forward to more interaction here!!
Best to all of you!
I also own a Polk Audio XM audio component box and repeater and could perhaps others with that equipment!!
