SDA 1-C Speaker Tweak re: Vibrapods
I recently tweaked my SDA 1-Cs using Vibrapods, and the results are so good I thought I'd post the tweak. I note I have the studio version of the SDA 1-Cs, and they have given me years of pleasure. I've been adding Vibrapods to all my separates, and the results (esp. under the CD player and turntable) have been so good I thought I'd try it on the speakers. The steps I took are listed below. Good luck to anyone out there who wants to try this tweak. Drop me a post if you have any questions, or if you just want to gloat over the results.
SDA 1-C / Vibrapod Tweak
1) Gently unscrew the 4 screws from the base of each SDA 1-C (while you have the screwdriver out, you might as well gently tighten up the screws holding the drivers and passive radiators). Set the bases aside - you'll need them later. Forget about the screws.
2) Measure the bottom of one of the speakers, and cut out a similarly sized piece of 1/2" thick medium density fiberboard (MFD). Repeat for the other speaker (you can prime and paint the MFD if you like - I didn't bother). I note I made my MFD boards about 1/4" longer on each side - it made the set up a little easier, but you don't need to do this.
3) The weight of each SDA 1-C is 85 lbs. I got the Vibrapd information and calculated I should use the following Vibrapods under each speaker: four #4s, and four #2s. Thus, I needed to purchase a total of eight #4s, and eight #2s. (I note the oak-finish SDA 1-Cs weigh in around 100 lbs each. You'll have to configure on your own what Vibrapods to get to displace 100 lbs. Simply go to the Vibrapod web site and look at the on-line manual/directions.)
4) Place each SDA 1-C base that you removed back where you had the respective speaker initially placed. Next, on each base, center one of the MFD boards you cut.
5) Now you have to position the Vibrapods. First, I placed one #4 Vibrapod in each corner. Next, I placed one #2 Vibrapod midway between the rear two Vibrapods, and one #2 Vibrapod midway between the two front Vibrapods. Then, on the left side, I placed one of the remaining two #2 Vibrapods a bit forward of the mid-point between the rear left and front left corner Vibrapods (I note the front portion of the speakers, due the postion and weight of the drivers, weighs more than the rear part.) I mirrored this procedure on the right side.
6) Grab a friend and one of the SDA 1-Cs, and gently position it on top of the Vibrapods. Do the same for the remaining SDA 1-C.
My results are as follows:
(1) Bass was much tighter and not boomy.
(2) Midrange was much tighter and defined (I note some persons feel the midrange on the SDAs is not as good as some speakers - wait until you hear the before and after difference with the Vibrapods!)
(3) High end is much more defined.
(4) Much more detailed music - I was hearing detail I never had before. Great clarity and superb imaging!
(5) More open and deeper sound stage.
I highly recommend this tweak. The total cost of my tweak was under $100: 16 Vibrapods, including shipping, was $87; this included a $7 discount due to a previous purchase, and free shipping. (Sorry Polk Store, I didn't buy this set from you because you charge shipping.); MFD sheet was $4.99 at Home Depot.
I spent 10 minutes total measuring and cutting the MFD. Add another three minutes to unscrew the bases. Add 10 more minutes to arrange the bases, MFD, Vibrapods, and speakers. I feel the return on this modest investment of time and $ was remarkable.
I also note the Vibrapods may take up to a couple days to settle in, but you should hear great results as soon as you do the tweak!
Post edited by dbnh on
Where did you order your Vibrapods from?Proud and loyal citizen of the Digital Domain and Solid State Country!
I got the Vibrapods from the following:
CJ's Audio Video, Inc.
www.cjsaudvid.com
847.566.8159 10am - 6pm CST
11am - 6pm Sat.
312.819.6033 FAX
http://www.cjsaudvid.com
Hope that helps.
Re: picture - never thought of taking a picture of my system. Guess I'll try to borrow my daughter's camera and post a shot. -
I've attached a lo-rez photo, as requested.
I have:
SDA 1-Cs tweaked w/Vibrapods
NAD 2200PE
NAD 1240 pre-amp
Sony turntable w/Otofon
Sony 5-disc CD changer
Kenwood tape deck
Monster Cable interconnects and speaker wire
Salamander rack
Vibrapods on separates
I should shortly have an Odyssey Stratos amp, with the 120,000 uF cap upgrade. Then its off to buy an Odyssey Tempest pre-amp. After that, save up some $$$ to get a Cary CD player (that could take some time) and call it quits for a while. Any suggestions for other high end CD players would be appreciated. -
One more photo for HBomb. Note the MFD board, if primed and painted black, would not be too noticeable.
