what would a 2 sub do
comet
comet Posts: 31
would it be worth getting or a bad thing to do
Post edited by comet on
  • etrigan
    etrigan Posts: 160
    edited March 2003
    :confused:
    CHEERS ! jefff
    Art as expression-Not as market campaigns-Will still capture our imaginations.
    VR3 Posts: 29,514
    edited March 2003
    Do you mean getting 2 subwoofers? How big is your room? What kind of music do you listen to? How loud? Details man, DETAILS
  • comet
    comet Posts: 31
    edited March 2003
    20'wide x 24' long. to add a 2 sud and heavy metal
    VR3 Posts: 29,514
    edited March 2003
    what is ur price range? what is your setup? (speakers, receiver, etc...)
    VR3 Posts: 29,514
    edited March 2003
    You have a very large room. What subwoofer do you have? Specs - Brand - etc..., If it is a pretty weak subwoofer you could benefit from a second subwoofer, all depends on your current subwoofer. Other than that all a second subwoofer does it produce more volume. I guess.
  • nealxam
    nealxam Posts: 1
    edited April 2003
    i have 2 psw450's listen to hip hop and movies in a small room. love it. ususally have one almost turned off though, but at least i will have two matching subs when i get a house that i can make a dedicated home theatre room in. currently would get evicted if even one was turned more than 1/4 of the way up but there's nothing better than knowing that you have it if you need/want it. it's not cheap running a long sub interconnect so i have them in opposite corners though.
    F1nut Posts: 51,912
    edited April 2003
    hip hop.....bounce hop, pfft!
    btw, Welcome to the forum.
