Holy @&%$ - Can't believe my wife just approved this speaker purchase
Pycroft
Since I upgraded to the RTA 11TL's, I needed a new center channel. My wife did NOT know this when I bought it. After I just sold what I had, she asked about it and I jumped on it. I gave her two options, between the CS400 and the CS350. The 400 is more expensive, but it's the one I want. Here's what I did I told her that the CS350 would have to go in front of the TV because it didn't fit on the shelves. The CS400 could be conveniently located under the TV (I know not ideal, but whatever), so she'll never have to see it. There's a picture of the stand in this post: http://www.polkaudio.com/forums/showthread.php?t=88585. I will be taking out the shelf that the CS1 sat on, so the speaker can fit height wise. It should squeeze in there perfectly otherwise. I told her it was more expensive, but, "Think of the other speaker being right in front of the TV, all our guests looking at it and commenting on it. And our daughter (Who's not yet two) would love to bang it and play with it. It would just be safer to get the CS400". I showed her pictures, and it was approved. It was a close one though (You should have seen her face when I began the conversation with, "We have to talk about something" and she replied, "Speakers?"
I'll pick it up tonight! Any comments on how the placement of the speaker below the TV will affect the sound. I had my CS1 down there, and I didn't htink it was too bad.
James
James
2 Channel/HT:
Sony SS-M9 P's (ES version)
Sony SS-M1CN Center Channel
Polk RT800 Surround Speakers
Odyssey Stratos Dual Mono Amplifiers
TAD 150 Signature Tube Preamp
Harman Kardon HK354
Sony SACD Player
Harman Kardon HK354
Sony SACD Player
Post edited by Pycroft on
Do you mean that the TV will sit on top of the center speaker ? Had that center at one time and it's a damn good one for sure,you'll be a happy camper. IMHO though,look into a different stand,if money is tight,you could probably make a decent one for pretty cheap. Don't forget that idea of yours will raise the height of the TV quit a bit too.HT SYSTEM-
lsi 9's -
TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
so by removing the shelf it will essentually sitting on the floor? anyway to re-mount the shelf a bit lower to give the new center more height?panasonic th-50pz85u
pioneer elite vsx-92txh
pioneer elite bdp-05fd
emotiva xpa-3
monster power hdp 2550
sa 8300 hd dvr
sda 2b's
fronts - rti a9's
center - csi a6
surrounds - fxi a6's
sub - polk dsw pro 600
harmony one -
Sorry I was unclear. If you look at the picture, the CS 1 is basically a foot below the TV on a shelf. Underneath the CS1 was a spot for books. Basically I will be removing the shelf the CS1 was on and making it one big area for the speaker. I will have to find another place for all the Dora the Explorer books. Hopefully it won't sound too bad down there, but it has to be a HUGE improvement to the CS1, and should sound fab with the RTA 11TL's.2 Channel/HT:
Harman Kardon HK354
Sony SACD Player -
Congrats on the CS400!Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
got that part, just wondering if you can remount the shelf just low enough to fit the new center while keeping it as close to the tv as possible - vs it being almost on the floor.panasonic th-50pz85u
emotiva xpa-3
sa 8300 hd dvr
sda 2b's
fronts - rti a9's
center - csi a6
harmony one -
Junior - that's impossible. The shelf thats above the CS1 in the pic is part of the main load bearing shelf. In the future, it may be possible to mount the TV on the wall and place the Center where the TV now stands. The problem is the wall behind attaches to the garage, and I don't think there's many studs behind that area. I guess I'd have to get lucky. I'd haate to mount it there and have it fall Just thinking there may be about 2 inches of extra room on teh bottom where I can at least prop up the front of the speaker to angle upwards. May help2 Channel/HT:
Harman Kardon HK354
Sony SACD Player -
That might be a little low, at least with the CS350 it can be flipped and angled up...just a thought. Congrats, thats a nice lookin set-up.Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
sounds like that may be your only short term choice. maybe make a little stand for it to give it a little height and angle it upwards? nice looking setup btw.panasonic th-50pz85u
emotiva xpa-3
sa 8300 hd dvr
sda 2b's
fronts - rti a9's
center - csi a6
harmony one -
I am pretty confident that the studs in the wall follow the standard 16" on center guidlines, so the wall should be ok supporting the tv, and it will make hiding the wires inside the wall a bit easier.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
“When once a Republic is corrupted, there is no possibility of remedying any of the growing evils but by removing the corruption and restoring its lost principles; every other correction is either useless or a new evil.”— Thomas Jefferson -
From the picture, the shelf is adjustable, using peg type shelf brackets. Just redrill a set of new holes. Easy-peazy.
Hints: I would make a little template with a scrap of thin wood (1/4") so you drill all exactly the same height. Also use tape on the bit so you don't drill too deep.
PS: Good job on presenting your case to the wife. -
nice! i would try and make it so that the speaker would be angled upward's slightlyMedia Room 7.1
Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
HTPC
Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
A fool and his money are easily parted
I don't drink Koolaid
Need some cable's? Just ask -
How about something like this to sit the speaker on or build one of your own as SJ suggests.
http://www.dynaudio.com/eng/systems/lines/accessories/centerbase2.phpMarantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
I will have about 5 3/8 inches of spare room in the bottom. I think my best bet may be to prop something under the front of the speaker to angle it up. Thanks for the comments and compliments -2 Channel/HT:
Harman Kardon HK354
Sony SACD Player -
what about just raising the upper shelf with these?
height is 8 1/8" to 8 5/8"
(if you have Ikea near you)
http://www.ikea.com/us/en/catalog/products/20049538
Oh my...I LOVE my new CS400. It sounds FANTASTIC with the RTA 11TL's. I just hooked it in, and put on Kill Bill Vol. 1 - the fight scene near the end with the Crazy 88's. It is like night and day compared to the CS1/Monitor 50's. I really feel like I have a FANTASTIC system. I will upload pictures later tonight...the in laws just got here. Thanks to everyone for the advice.
And Kcroc - Thanks for the advice on those shelf raisers. That sounds like a great idea I think...something the wife may even go for for a bit of money
James2 Channel/HT:
Harman Kardon HK354
Sony SACD Player -
Oh my...I LOVE my new CS400. It sounds FANTASTIC ...
BTW, those Ikea feet that were recommended above: not only do they look pretty darn good, but they come from the kitchen department, and will therefore hold something like 200lbs or more. They also cost next to nothing, and have height adjustment capabilities built in.
Best of luck!Alea jacta est!
