SDA-1C Crossover's the same or is there a left and right?
Conradicles
Conradicles Posts: 6,390
edited August 2014 in DIY, Mods & Tweaks
Help! I took out both crossover's to remove the polyswitches and forgot which one goes in the left and which one goes in the right cabinet.
If they are the same and it does not matter, then why are the black wires that connect the inductor to the PCB opposite on each crossover? (it may be hard to tell from the picture, but they are)
If the crossovers are identical, then are one of mine wired wrong?
Help folks, I am a bit confused.:confused:
Thanks to all.
Eric.
Post edited by Conradicles on
