Subwoofer Hum
Pizdook
Pizdook Posts: 2
edited October 2009 in Troubleshooting
I'm using a PSW505 subwoofer and I recently got a new Denon AVR790 receiver and all of a sudden I have some low frequency hum coming from my subwoofer when the receiver is off and the subwoofer is in the auto state (so it doesn't go to sleep after 15 minutes). My old receiver was an Onkyo RT-530 (from a HTIB) and when I got the subwoofer I had the same sort of problem but moving the subwoofer cable away from the speaker cables seemed to help things and the hum went away, but that fix doesn't work with this new denon receiver.
Just some other information...
If I turn the sub into standby mode there is no hum.
When I have the sub plugged into the wall without any cable running to the receiver there is no hum.
When I have the sub plugged into the receiver and the receiver is on there is no hum, but when I turn the receiver off the hum starts.
I do not have cable TV so there is no coax cable plugged into the TV.
I have tried multiple outlets and that changes nothing.
For the subwoofer cable I'm using a 25 foot Belkin Pure AV cable. Would having a short subwoofer cable eliminate the humming? or is the belkin pure AV cable pure cr*p?
I'm not sure if this is a ground loop or electromagnetic interference problem. but if anyone has advice/information it would be appreciated.
Post edited by Pizdook on
  • ben62670
    ben62670 Posts: 15,969
    edited September 2009
    A real quick test is to try using a cheater plug. They are the ones that adapt 3 prong AC plugs to 2 prong outlets. The Belkin wires seem decent, but that is a long run.
    Ben
  • dudeinaroom
    dudeinaroom Posts: 3,609
    edited October 2009
    http://www.polkaudio.com/forums/showthread.php?t=88698&highlight=ground+loop
    http://www.polkaudio.com/forums/showthread.php?t=88461&highlight=ground+loop
    http://www.polkaudio.com/forums/showthread.php?t=87755&highlight=ground+loop
    This site has an awesome search feature.:cool:
    The problem could be coming form a few different places.
    A cheater plug works, but there is a reason why they call them a cheater plug.:rolleyes:
    Welcome to Club Polk.
    Hang around there is a lot to learn on the forum pages here.
    Later,
    dude
    ****Edit****
    Sorry Ben, I guess you did say as a test.
  • sTiLlLeArNiNg
    sTiLlLeArNiNg Posts: 805
    edited October 2009
    If possible i would try a different cable, a shorter one would be better if you don't need the 25' length. I am inclined to say that it is an EMI problem
    Media Room 7.1
    Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
    HTPC
    Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
    A fool and his money are easily parted
    I don't drink Koolaid
    Need some cable's? Just ask :)
  • danz1906
    danz1906 Posts: 5,144
    edited October 2009
    ben62670 wrote: »
    Agreed,that should work.
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
