Need one 7 1/2" (190mm) midrange for my S10....
buzzardmountain
One of my midranges is blown......
Polk doesn't make these anymore.......Any ideas where to look???
I don't want to trash these......what can I replace the speaker with???
Post edited by buzzardmountain on
Try posting a want to buy ad here...someone might have the mid-woofer that you need laying around.
Keep your eye on ebay too, they pop up on there from time to time.
Good luck with your search.
edit-What's the model number on the mid-woofer that was blown?The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
comfortablycurt wrote: »Try posting a want to buy ad here...someone might have the mid-woofer that you need laying around.
Not sure the model number on the mid-woofer.......I'll take it out of the cabinet tonight and look......all I know is from this pdf of the owners manuel.....
http://www.polkaudio.com/downloads/manuals/home/S-series_Manual.pdf -
buzzardmountain wrote: »Not sure the model number on the mid-woofer.......I'll take it out of the cabinet tonight and look......all I know is from this pdf of the owners manuel.....
Here's a little more info on the S10's...Scroll down to post #7 of this thread for a wiring schematic...
http://www.polkaudio.com/forums/showthread.php?t=38755
According to that, there were two versions of the S10. The standard S10, and the S10SE(I assume "SE" is special edition). It looks like the standard S10's used the MW8000, and the S10SE used the MW8101.
My best guess is that you need an MW8000, but you'll definitely want to pull the driver to make sure. Polk is known for having a lot of transitional models, and using different components within the same series of speakers.The nirvana inducer-
based on the product page it is the MW8000 Dynamic Balance 7.5" driver.
Although the wiring diagrams also have a SE version that had MW8001 driver.
http://www.polkaudio.com/homeaudio/products/recent/s10/
standard S10 w/ MW8000
http://www.polkaudio.com/forums/attachment.php?attachmentid=18699&d=1155781468
S10 SE with MW8101
http://www.polkaudio.com/forums/attachment.php?attachmentid=18700&d=1155781486 -
While surfing on CL, I came across this ad for a pair of MW8000's
http://omaha.craigslist.org/ele/1371666074.html -
Thanks for the help......I found that ad this morning on a google search and possibly an ad he had on the DIY forums from June......
http://www.diyaudio.com/forums/showthread.php?t=146177
Seems like the same person.......just wanting to be very careful and make sure it's not someone scamming using the picture.
I sent him an email and PM.......I'll let you know how it goes.
R. -
I think some of Thomas Wyatt's poems are equally beautiful.
Reported
