slight static sound with voices
royalty
royalty Posts: 246
edited September 2009 in Troubleshooting
I think this really only happens when watching dvds.....When watching a dvd, during many movies when someone talks in the movie there is a slight static/ distortiony sound to the voice. This happens on high or low volume. I have eliminated the possibility of it being the player or the center channel. So decoder or are many dvds just poorly produced?
-To add, this noise is VERY slight but certainly audible
HOME AUDIO:
Electronics:
HK 354
Front Power: CARVER TFM-35
Center Power: Audiosource Amp One
Speakers:
Center: CSi5
Fronts: rti10s
Rears: monitor 50s
psw 125 + psw 505 = BOOM
CAR AUDIO
Infinity 6032CF's all around
Post edited by royalty on
    treitz3 Posts: 19,256
    Check your cable connections or replace them. See what happens then get back to us.
  • nms
    nms Posts: 671
    maybe distortion purposefully added to the sound track? I know a lot of radio ads do that to make the voices more attention-grabbing, but it's annoying as you-know-what.
    My system
    "The world is an ever evolving clusterf*ck." --treitz3
  • Pizdook
    Pizdook Posts: 2
    Maybe a tweeter on one the front channels is blown.
  • nms
    nms Posts: 671
    Let's get a little more serious here. What system are you using to listen to movies (how many speakers and what arrangement)? Do you use the same system to listen to music, or do you reduce the number of speakers to a conventional stereo setup?
    It could be any number of things: outputs for one channel are bad on your receiver, one set of cables is bad, connections are bad for one speaker.... etc.
    You could try disconnecting all except one speaker and play a known "static-y" track or section. Alternate which speaker is plugged in until you find which one is bad. If multiple speakers are bad, then the problem is probably in the receiver.
    HTH
    My system
