problem with amp or speakers??
snaffles
snaffles Posts: 3
edited September 2009 in Troubleshooting
i was having a party yesterday and had my speakers loud all of a sudden they went really quiet, still sound coming through them but very low , no bass, seems fine through headphones.
im wondering if we have blown the speakers or maybe the amp.
its a sherwood rd611 amp and eltax liberty 5 floorstanders
Post edited by snaffles on
    treitz3 Posts: 20,117
    Make sure that the speaker selector switch is engaged.
  • snaffles
    snaffles Posts: 3
    i will try that thankyou .
    also when i plug headphones in the music still comes from the speakers lowly but sounds correct when coming out of headphones, is this right ??
    thankyou if you can help
    If that doesn't work, press the tape loop switches [bypassing the tape loop] until the signal returns. Just keep the volume down.
  • snaffles
    snaffles Posts: 3
    thankyou , im not very technical so not sure what all the buttons on the amp do , so will check do you think that something has maybe been pressed that shouldnt have been ??
    Yes. The system should be fine.
