Best audio $$$$$$ I have ever spent.
Polk user
Polk user Posts: 311
edited September 2009 in The Clubhouse
I bought 20 of these and after the install my highs were higher and my lows were lower. I have MUCH more clarity. I never would have believed that raising my speaker wire off the floor would make such a difference. Wish I had done this sooner.
Post edited by Polk user on
  • SolidSqual
    SolidSqual Posts: 5,218
  • kevhed72
    kevhed72 Posts: 5,059
    I am skeptical, but not closed minded, and need someone to explain this...
  • madmax
    madmax Posts: 12,434
    Not sure but a few things come to mind. No charges from the floor, capacitance/inductance changing less and causeing no charges, less vibrations to move the cable around. I don't quite grasp it.
    madmax
    Vinyl, the final frontier...
  • sTiLlLeArNiNg
    sTiLlLeArNiNg Posts: 805
    i remember briefly reading a thread last week or so suggesting something like this but using ceramic's and vegetable's? lol
    do they truly work? if so why not make your own? seem's simple enough....
    what is the theory behind these on how they work?
    Media Room 7.1
    Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
    HTPC
    Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
    A fool and his money are easily parted
    I don't drink Koolaid
    Need some cable's? Just ask :)
    mhardy6647 Posts: 33,905
    the basic notion seems to be trading the dielectric of the floor/flooring material (e.g., synthetic carpet) for air.
    Here's an example, with somewhat less hyperbolic ad copy than I remember from his paper catalogs...
    http://www.mapleshaderecords.com/audioproducts/cablelifts.php
  • lanion
    lanion Posts: 843
    Well your wire is carrying a current and thus will create a magnetic field around it. Inducing a magnetic charge in the floor could then cause the floor to induce some electrical interference in your wire and thus make your signal noisier. Now, the dielectric potential of wood floors is quite low while that of carpeting can vary quite a bit.... but its never going to be that high. Over a long cable run it could add up to something though. Im sure the effect of these thinsg would be scientifically measurable, but its up to you if youc an hear it.
    Most of all they really just overcharge for these things. You would do just as well propping them up with some paperback books every couple feet to see if it makes a difference. If you notice anything go ahead and buy something more attractive.
    My Iron Man training/charity blog.
    HT:
    32" Sharp LCD. H/K dpr 1001 to Outlaw Audio 7900 to Polk LSi + Paradigm Studio center. Hsu DualDrive ULS-15. PS3/Wii. Outlaw 7900.
  • kcoc321
    kcoc321 Posts: 1,788
    I wondered about this when I saw the "produce standoffs" thread,
    There are similar standoffs that are used for rebar when pouring footings.
    IDK why they wouldn't work and are alot cheaper, $1.80 ea (2.25"h)
    http://www.lowes.com/lowes/lkn?action=productDetail&productId=212684-157-05958&lpage=none
    they also have them in 3.25"h for $2ea.
    btw the saddle is 1/2"-5/8" dia, so most cables should fit easily...
  • Polkitup2
    Polkitup2 Posts: 1,622
    Polk user wrote: »
    But were your mids middier? :rolleyes:
  • Kex
    Kex Posts: 5,200
    Polk user wrote: »
    I bought 20 of these and after the install my highs were higher and my lows were lower. I have MUCH more clarity. I never would have believed that raising my speaker wire off the floor would make such a difference. Wish I had done this sooner. ...
    I suppose we should be happy that tags are not around at this point ... I hate to think what the "cable nonsense" tagger would be adding on this thread!
    It's not something I'm likely to be considering in the next ten years, regardless, but congratulations on the added enjoyment of your system, Polk user!
    Alea jacta est!
  • sTiLlLeArNiNg
    thank's for the explanation's boy's :)
    guess i'll be OK cuz i have wood laminate floor's and my media room is smaller than my washroom! lol
    Media Room 7.1
    HTPC
  • madmax
    Some people hang their cables from the ceiling with fishing line.
    madmax
  • dee1949
    dee1949 Posts: 1,425
    ...cheap alternative to give it a try is Styrofoam cups
  • danz1906
    danz1906 Posts: 5,144
    dee1949 wrote: »
    That just might work:p
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • warren
    warren Posts: 756
    What about TV cables, Comcast,AT&T U- Verse, etc; electric, and phone cables that are burried under ground? Would they sound better, and the picture clearer if they were suspened in the air by poles?
    Some final words,
    "If you keep banging your head against the wall,
    you're going to have headaches."
    Warren
