SDA SRS 1.2 binding post polarity
michaeljhsda2
My friend Jerry just bought the 1.2's from Speedy and I was wondering if the binding post polarity is correct. The following pic shows the positive on the right as seen in the photo, however, the positive is on the left on my 1.2 TL's. Any thoughts? Thanks
Mike
Mike
SDA SRS 2.3TL's
SDA 2B TL's
SDA 2B TL's
Post edited by michaeljhsda2 on
where's the beef... I mean pictures?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
“When once a Republic is corrupted, there is no possibility of remedying any of the growing evils but by removing the corruption and restoring its lost principles; every other correction is either useless or a new evil.”— Thomas Jefferson -
I think the problem is one set is original SRS's.Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
Cary SLP-05/Ultimate Upgrade.
Cary SA-500.1 ES Amps
Cary DMS 800PV Network
Jolida JD9 Fully Modified
VPI MW-1 Cyclone RCM
MIT Shotgun 3 cables throughout / Except TT, and PC’s -
Speedy advertised them as SDA SRS, do the serial number plates say otherwise?
Anyway, I seem to recall that the SDA SRS have the positive on the right, but that later versions have the positive on the left. If you want to be 100% sure (I would) pull the crossover plate and follow the binding post leads to the crossover connections, which should be marked + and -.Political Correctness'.........defined
President of Club Polk -
Serial numbers are 5016 and 5038. I am also trying to figure out if these are 1.2's as they are pin/blade. He advertised them as SDA SRS but his signature lists them as 1.2's. I asked Speedy if I could put RDO 198's in them and he said yes (the crimp connectors on the positive wires would have to be replaced with a wider connector to accomodate the wider post). I read in the forum that way back when you could buy an upgrade kit from Polk and convert them to TL's along with replacing the tweeters with SL3000's and I'm wondering if this why Ben did the upgraded XO's.SDA SRS 2.3TL's
SDA 2B TL's -
Thanks, I'll check it out.SDA SRS 2.3TL's
SDA 2B TL's -
I'm also going to pull a stereo and a dimensional MW and see what version they are. I'm hoping these can be converted to TL's....I commented in the FS thread about this possibility.SDA SRS 2.3TL's
SDA 2B TL's -
SDA-SRS 1.2
-Small PCB crossover - yes
-Different driver rows - ?
-Cut/molded cabinet structure - yes and they have the exact same internal cross
bracing as my 1.2 TL's.
-9-screw panel(?) - Polk used spare parts from previous models as a cost cutting measure
-Blade/pin interconnect - YES!!!!!! I think these are 1.2's. Did Polk ever make a SDA SRS with a pin/blade? If not they have to be 1.2's, right?
Stereo MW is 6503SDA SRS 2.3TL's
SDA 2B TL's -
If all 8 drivers are 6503's then they are SRS's not 1.2's or tl'sPolk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
I pulled the crossover out .....and THE BINDING POST NUTS ARE ON THE WRONG POSTS!!!SDA SRS 2.3TL's
SDA 2B TL's -
michaeljhsda2 wrote: »I pulled the crossover out .....and THE BINDING POST NUTS ARE ON THE WRONG POSTS!!!
Can you post a pic of the crossovers?Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
TOOLFORLIFEFAN wrote: »Can you post a pic of the crossovers?
Yes but my camera battery just died. Give me about 15 mins. In the meantime are there any SRS's that are pin/blade?SDA SRS 2.3TL's
SDA 2B TL's -
MW are dated 1988SDA SRS 2.3TL's
SDA 2B TL's -
picsSDA SRS 2.3TL's
SDA 2B TL's -
picsSDA SRS 2.3TL's
SDA 2B TL's -
I found this extremely helpful when I pulled out my drivers for some treatments.
- http://www.polkaudio.com/forums/showthread.php?t=55888
I just keep it bookmarked as a reference now.Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
They were definitely reversed.SDA SRS 2.3TL's
SDA 2B TL's -
yes i did the same.SDA SRS 2.3TL's
SDA 2B TL's -
You have 1.2's when you get the RDO 198's you will have to terminate the colored wires on your tweeters to 1/4" terminal's then you will have the 1.2tl's.
Congrats!!!
Ben did the same work on my 1.2's to 1.2tl's...
Enjoy your tunes!!!
Larry.Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
Not sure how many hours are on those crossovers, but after about 150-200 hours you will notice a big difference in the low end, the bass will knock you back in you seat.Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
Thanks for the confirmation Larry.
YAHOO!!!!!!!!!!SDA SRS 2.3TL's
SDA 2B TL's -
When I listened to them yesterday at Speedy's they sounded awesome. I questioned the polarity but I was only able to confirm this morning that Speedy had them hooked up in reverse polarity.SDA SRS 2.3TL's
SDA 2B TL's -
Also if these speakers are not spiked, Spike them don't think about it "just do it".
Also get some dynamat for the driver's, But I say spike them first you will be amazed.
SVS SB16 X2
He only listened to them a few times after Ben did the upgrade so I'm not sure how many hours are on them but they sound fantastic now.SDA SRS 2.3TL's
SDA 2B TL's -
yes I spiked my 1.2TL's and since they are on a concrete carpeted floor it made a huge diff.SDA SRS 2.3TL's
SDA 2B TL's -
Any concerns with running SL 2000's in them for the time being until I replace them with RDO 198's?SDA SRS 2.3TL's
SDA 2B TL's -
Even if they're 1.2's, RD0-198's will not work unless you make changes in the crossover.
1.2 Schematic.
1.2TL Schematic."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
So this means Larry doesn' have TL's?SDA SRS 2.3TL's
SDA 2B TL's -
michaeljhsda2 wrote: »So this means Larry doesn' have TL's?
I have the tl upgrade,crossovers and RDO 198's, and if Ben did the same work on yours then you do as well.:cool:Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
Technically, no. But, his crossovers were modified so they're now the same as 1.2TL's."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Correct!!!:cool: and I am glad I had it done..Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
