dsw sub remote problem
Mark1
It seems my remote is unresponsive when I try to use it at first. If I keep pressing buttons on it it eventually starts working and then it will work till I'm done using it flawlessly. Later if I pick it up to control the sub i'll have to start pressing buttons for another couple minutes before it works again.
Anyone else have similar experience with the remote. I took out the plastic tab on the battery and its in there the right way. I'll pick up a new battery tomorro to see it fixes it, hopefully the battery is just weak.
Post edited by Mark1 on
Was a dieing battery! Thats good news. Although the replacement was 6 dollars. Oh well I'm happy now.
