1st HT System EVER - All Polk - Advice Needed
Hi Guys..
Glad I found this forum BEFORE I made my first HT system purchase. The only thing I know for sure is I WANT Polk speakers around the room.
Here is the package I have come up with that should keep me within "wife approved budget".:
Center Channel: LCI-C
Front L/R: LSI9 or most likely LSI7 to reduce cost
Sides: FXIA6
Rears: RC80i
Subwoofer: PSW111 or PSW125
Receiver: Pioneer VSX-1019AH-K
Any thoughts/advice you can give would greatly appreciated. Again this is my very FIRST system and I'm just trying to get a good sounding foundation and I need to make sure I'm not making any big rookie mistakes with the above selections.
Thanks!
Jim
Sides: FXIA6
Rears: RC80i
Thanks!
Jim
Post edited by Motorcity on
Those speakers are rated at 4 ohms, the Pioneer receiver is not. You will probably not benefit from the LSi series qualities in this configuration. Also, if the priority is HT, not music, then the LSi might not be the most obvious choice in any case. I would suggest:
- Change LSi choices for RTi or TSi series, 8 ohm speakers.
- RC80i rear channels can stay the same.
- Spend the money saved on a better subwoofer (expect $500 or more).
Those are just some ideas to send you in a different direction, unless you change the receiver, or add an external amplifier. There are plenty of alternatives, but I think starting out with an LSi based Home Theater, driven by the Pioneer, is not an appropriate choice.
Welcome to CP BTW!Alea jacta est! -
Kex has got you pointed in the right direction for sure. Im upgrading my R50's to RT's sooner or later.Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
+1; for HT and a receiver as power, you'll be perfectly happy with the RT lines. Also agree on a beefier subwoofer._________________________________________________
Thank you very much guys! I had no idea about the 4-8ohm issue.
I was going on the premise a couple "experts" told me to always get the best speakers you can afford, and if you have to sacrifice do it with the receiver.
What are you thoughts on the units I have selected for the left and right side walls and the center channel?
Thanks again this is a HUGE help for me.
Jim -
Like Kex said, the surrounds are OK, go with the RT line......
http://www.polkaudio.com/homeaudio/rtia/Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
Welcome to Club Polk.
Get the larger of the 2 RTI center channels. Also make sure that whatever receiver you get has preamp outputs to add separate amplification later on down the line to ensure that your speakers operate to their full potential.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
+1 with Cfrizz, get the CSiA6 and go for the RTiA9 or 7s, paired with the matching surrounds and a Pioneer Elite SC-05 AVR. For subwoofer look at SVS and choose one, they are all good. www.svsound.com, Welcome to the club also.Shoot the jumper.....................BALLIN.............!!!!!
Thanks for the replies guys... A few more questions..
The only issue is that I can't go with the towers so I have to use two bookshelf speakers. Is the RTi A3 the way to go here?..
The center channel needs to be in-wall. Would I be ok with the one on my original list the LCI-C?
And last question.. Everyone is recommending a better subwoofer. Are the Polk subs not a good option at all? Do I need to go with the DSW line at minimum? or switch to another manufacturer?
Thanks again everybody..
Jim -
I am with the guys here, upgrade your AVR to one that pre-outs (they will come in handy later) and get either the RTi, or Monitor line. The Monitors IMHO, can't be beat for HT at the prices they can be had for these days. As for the Subs. Polk subs aren't bad, just not their strong point. I have a PSW125 and it works great in my humble setup in my small space. Have heard good things about the DSW line, and also for SVS, Epik, Velodyne, but they tend to be on the pricy side. In the end it is going to be up to you and your budget, check your local Craigslist and even Ebay. If you can get your ears on some of these subs first that will also help. Hope we have been able to help you, and welcome to Club Polk.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
It's not that I'm insensitive, I just don't care.. -
Regarding the pre-out.. This is a picture of the back of the Pioneer I was considering. It does say "Pre-Out" but also says subwoofer in the same area.
Is this what you guys are talking about? Sorry for the basic questions, but this is all new to me.
Jim -
... The only issue is that I can't go with the towers so I have to use two bookshelf speakers. Is the RTi A3 the way to go here?..
And last question.. Everyone is recommending a better subwoofer. Are the Polk subs not a good option at all? Do I need to go with the DSW line at minimum? ...
The LCi-C, however, will not be a good match for those, since that matches the LSi line, and is rated at 4 ohms. You should match the center channel as closely as possible to the main, left & right front, speakers. I believe the RCi is the correct series to match with the RTi A, but you might want to call, e-mail, or chat online with c/s to verify that (something seems to be wrong with navigating that area of the website at the moment).
As far as subwoofers go, some of the newer Polks are much better than the older models. I can't recommend a specific unit, since I've never heard them or researched them in any depth, but look for a lower 3dB limit below 30Hz. The best models in the $500-750 range should be approaching 20Hz or lower. Otherwise, a quick search of older threads here will identify a multitude of other brands, such as SVS, HSU and others. Note that musical priority, vs. theater applications, will change how people rate the different models dramatically. Generally speaking, a "musical" subwoofer will probably be less "boomy", but may not shake the house as dramatically for explosions etc. Preferences either way will vary.Alea jacta est! -
http://manuals.harman.com/HK/HOM/Quick%20Start%20Guide/HK_AVR254RearPnl.pdfAlea jacta est! -
with ur budge i would go for RTIa3 and a superb subwoofer and receiver with preout (Pionieer elite, HK AVR254, Denon 2909/989 (they should be on sale by now).
i woundnt condsider 7.1 unless ur room has the oppotunity to place them perfectly.
if u do, go get another pair of RTIa3/1 for side. FXIa4/6 r best for rear, when hanged in backwall, 2 ft above ur sitting position.
subwoofer go for DSW Pro500/600 or DSW MIcro 1000Front: Martinlogan ESL
Center: Martinlogan Stage
Rear: Martinlogan Motion 4
Sub: Martinlogan Grotto-I
Receiver: Pioneer Elite SC 1523K
PC 2 Channel: Polk LSI7
Headset: Grado RS2 + Grado RA1 amp
Mic: Neumann KMS605
Car Audio
2002 MB C240 Sedan
MM6501 components
MM840 sub
MB Quart Onyx 4.60 (1/2 to components, 3/4 bridged to sub)
Pioneer 8200BT HU -
Jim
The Rti-a3 is an excellent choice for mains. I used the Rti-6 for mains in my early foray into H/T, and they dont disappoint. The A-3 a real nice makeover of the 6, but essentially the same speaker. Another member on the Forum here has an awesome setup featuring the A-3s as mains. (Erik Tracy) Dont know how the LCI-C center "timbre" matches with the A-3s, but you cant go wrong with the Csi-a6 for a center, if you can find an alternative location or mounting option. Have heard great things about Polks "Micropro" line of subs.:D
Pat.Receiver: Pioneer Elite SC-05
Amp: Emotiva Xpa-3
Front L/R: POLK Rti-a9s':D
Center:POLK Csi-a6
Rear surround's:POLK Rti-a1s'
Sub: Klipsch Synergy sub-12
Sony Kdl-46w4100 46" LCD
PS3
Audioquest type 4 wiring. -
It would help to know the dimensions of the room, and the budget (to lazy to look up the prices on your equipment list). Is the sub for HT only or music too? The LS speakers sound great, don't know about the in wall version. I strive for timbre matching not just for movies but because I like 5 channel stereo, DVD A and SACD. Who knows maybe Blue Ray will usher in a new music format 7.1. I wasn't happy with my home theater until all the speakers were a timbre match. Just keep that in mind. I guess we should ask someone else if the LCI-C's are a timbre match with the FSIA6 or the RC80i and whatever front speakers you decide on. If not you are in a pickle if the LCI-C is not a timbre match.
IMHO
G -
The RTi A3 will be a good choice for bookshelf mains if you don't have room for floorstanding models.
What Kex said.:D
Amp: Emotiva Xpa-3
Center:POLK Csi-a6
PS3
Correct, well put Kex. Guess I should read these threads more thoroughly.
G -
Budget? This will help .
tool rules
You don't want a LCI-C it is 4ohm & will not match the rest of your RTI speakers.
Go with the DSW series of subwoofers. I have the 400, my brother has the 500 & both will rattle your floors, but the 500 will rattle them more.
Your receiver does not have preouts for all channels. You would have to get a different receiver. The ones with preouts cost more money but it's worth it in the end.Thanks for the replies guys... A few more questions..
JimMarantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
