"High End" Receiver
tryrrthg
I am looking for a "high end" receiver from the likes of Rotel or Arcam. I would consider NAD or B&K also, but I'm not as familiar with those brands so I'd have to do some research.
Something like the Rotel RSX-1065 or 1067 would be ideal, but the 1055 or 1057 would probably work too.
Needs to have preouts. Not looking to break the bank either, but let me know what you've got. Thanks!
Post edited by tryrrthg on
What did you have in mind spending $$ ?
also would you consider separate components. -
It isn't on your list, but I would consider Primare as well: http://cgi.ebay.com/Primare-SPA-21-Surround-Sound-Receiver-Must-See_W0QQitemZ290337567278QQcmdZViewItemQQptZReceivers_Tuners?hash=item439977b22e&_trksid=p3286.c0.m14(no affiliation)
The SPA22, which replaced the 21, sells new for $5K, and sounds VERY good for the money. The 21 is very close in performance, and can found at reasonable prices at this point.Tschüss
Zach -
Not sure yet on the budget, just want to see what my options are before deciding...
I have looked at a few seperates options. I'm open to them also but am leaning towards a receiver. depends on what I can find, and at what price.
Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
okiepolkie wrote: »It isn't on your list, but I would consider Primare as well: http://cgi.ebay.com/Primare-SPA-21-Surround-Sound-Receiver-Must-See_W0QQitemZ290337567278QQcmdZViewItemQQptZReceivers_Tuners?hash=item439977b22e&_trksid=p3286.c0.m14(no affiliation)
That looks very nice! but probably more than I want to spend on a receiver...Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
Why don't you get something like a Onkyo or HK with pre outs? You'll be missing out on the new audio formats and such with an older unit. Or are you looking to replace the Arcam A85?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Even a decent Denon, with pre-outs(the one in my signature is for sale
) would work. I understand you are looking for "high end," which is why I suggested the Primare, but even at used prices, I'm not sure you are going to find a receiver current enough to be worth an upgrade. Tschüss
Zach -
HT System
Parasound Halo A51 Amp, Marantz AV 8003 Pre, Arcam FMJ CD36 cd player, Marantz 7007 BD/SACD player,Acoustic Zen Matrix IC's, Analysis Plus Crystal Copper Oval IC's, Acoustic Zen Satori speaker cables, B&W 703's Fronts, Center Martin Logan Motif hybrid, Surrounds DefTech BPX, 2 X DefTech Supercube Reference Subs, DSpeaker Antimode 8033 EQ. -
I have a receiver with preouts. I'm looking to move everything I have now for more of a one box (less expensive) solution. My setup is too complicated for my life right now. I have an 18 month old son that keeps me too busy for a whole lot of music/movie use. I need something simple (yet still sounds good) until we move to a new house and I can get my man cave back.
So I was hoping to find a decent receiver that will sound good for music, which is more background noise anymore, than sitting down and listening. I dont need the latest and greatest receiver for the new formats because my blu-ray player has analog outputs for that stuff. I dont use video switching on receivers since I like to have the option of watching TV with and without the receiver being on.
basically I am chasing my tail like most audiophiles do.
I use an NAD T765 and I love it. It's good for music too.
Not very high-end, but Pioneer SC-07/SC-09, Onkyo 805/875/905/906, Denon 3808/4308/4310/5308 or comparable Marantz should fit the bill.Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
Looks like someone might get a nice receiver for a good price here...
http://cgi.ebay.com/NAD-T773_W0QQitemZ180392854961QQcmdZViewItemQQptZReceivers_Tuners?hash=item2a004085b1&_trksid=p3286.c0.m14
good luck in your search. -
FWIW, I tried a big dollar receiver/pre pro and found it was lacking in two channel compared to a much cheaper dedicated two channel setup. I realize you're not doing much critical listening at the moment, but in the future you may regret selling off what you have now."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
I have a B&K AVR 507 S2 that I could part with. Hit me via PM to discuss.
Oh, and no preouts needed with this receiver as most typical HT amps won't touch what this thing is already pushing in its powerful chassis.
Okay, I am a little biased, like the receiver, but it's 150 REAL wpc. More into 4 ohms. Didn't break a sweat running 2 channel and/or 5 channel LSi Lineup.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850 -
I will probably agree with you but right now I just don't want all the boxes. and in the future I wouldn't want what I have nowFWIW, I tried a big dollar receiver/pre pro and found it was lacking in two channel compared to a much cheaper dedicated two channel setup. I realize you're not doing much critical listening at the moment, but in the future you may regret selling off what you have now.
it's nice sounding but with more room it would not be my first choice. Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
It's probably more than I want to spend but hit me with a PM in what you are thinking for price. Thanks!I have a B&K AVR 507 S2 that I could part with. Hit me via PM to discuss.
Okay, I am a little biased, like the receiver, but it's 150 REAL wpc. More into 4 ohms. Didn't break a sweat running 2 channel and/or 5 channel LSi Lineup.Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
I'm not sure if you wanted this to work as a dual HT & music system, but if you only need to power two speakers for music, perhaps you should consider the JoLida hybrid integrated units. They are very compact, and give the added advantage of letting you experiment with the tube pre-amp section.
Even the 1301, rated at 30w/ch for the solid state amplification section, will probably surprise you with it's abilities, and they can be bought used for about $200 and up currently. The more powerful 1501 is at least $500 used AFIK, so that may not work out when compared to the used sale value of you current integrated. If interested, you could try my 1301 out for free if you like, to see if you like that option (just pay shipping costs & insurance). I'm guessing that you would not be sacrificing much, if any, sound quality when compared to the Arcam with this option. They will only drive 8 ohms, AFIK, however.
http://www.jolida.com/catalogue/hybridamp.shtml
Of course, that would be a non-starter if you also want this solution to work for surround sound HT, and in that case, I'll make the same offer for the NAD, if you want to try it: just pay shipping (but at 50lbs, that's not as easy a "free" trial as the JoLida would be).
Not sure how I missed this post yesterday. Thank you very much for the offer! This place is great!
As nice as the offer is with the Jolida, it's not really something I'm looking for. I am looking to go with a single receiver to give me good sound for music and movies. In my current setup and situation I just want a simple one box solution that will fit my needs for a year or two until we move to a bigger house and I can have my man cave back.
I'm still considering your NAD receiver but I'm still doing some reading on a couple other options. Thanks again!Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
This is the NAD receiver that I use. If you buy it you won't need further amplification.
http://www.audiogon.com/cgi-bin/cls.pl?miscrcvr&1255063293&/NAD-T765-AV-Surround-Sound-Rec -
look here at this carver http://www.carveraudio.com/phpBB3/viewtopic.php?f=126&t=9799
