Center channel with Rti38 fronts
I have a pair of Rti38 bookshelf fronts. Any suggestions on a small center channel? I can't fit the CSI models. Would the RM models pair correctly?
Post edited by hypemfp on
I would try the CS245i. They are fairly easy to find used, and quite an excellent center (it's the only one I have left at the moment). They can also be quite a bargain sometimes, probably in the $50-125 range, depending on condition. The CSi30 will also match equally perfectly, but I don't think I see those for sale as often. If you want a little more impressive performance, the CSi40 is probably the very best choice, but may not be cheap, even used. Check dimensions also for your space: the best centers can be surprisingly large sometimes!
Welcome to CP, BTW!
http://www.polkaudio.com/homeaudio/products/recent/rti38/
http://www.polkaudio.com/homeaudio/specs/recent/cs245i/
http://www.polkaudio.com/homeaudio/specs/recent/csi30/
http://www.polkaudio.com/homeaudio/specs/recent/csi40/Alea jacta est! -
+1 on the CSI 30 or 40.
Pauly
If he wants a new product, then he should probably check the CSi A4. Generally, I think it's far more preferable to get a matching center from the same generation if possible, even when that means buying used, but any Polk speaker I have ever matched with newer generation centers has always blended admirably well nonetheless.
http://www.polkaudio.com/homeaudio/center.php#rtia
This page from the FAQ support section needs updating IMO, with all the new models currently available!
http://www.polkaudio.com/education/showanswer.php?question_num=63Alea jacta est! -
I ran the RT35i's with the CS245i for some time and found the combo to my liking. I just dumped the CS245i on CL for $60.00. You should be able to find one.
