SDA SRS 1.2tl side panels
Toolfan66
Are the side panels glued and stapled? and how hard are they to get off?
Thanks,
Larry.
Thanks,
Larry.
Post edited by Toolfan66 on
PM Lasareath (Sal) or Jesse. They've removed them. BTW they are not glued or stapled they are held by plastic hooks. I believe Sal has pictures of them in his signature.
I have took mine off several times to clean the cloth, I suggest you get a couple of thin blade putty knifes and slowly but surely pry them out then use a little thicker tool once you have a gap being careful not to damage the front or back while doing this, they can be stubborn and very resistant to your efforts just take your time.TOOLFORLIFEFAN wrote: »Are the side panels glued and stapled? and how hard are they to get off?
Thanks,
Larry.
REGARDS SNOWWell, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
DarqueKnight wrote: »
Thanks!!!! Thats what I was looking for.
