Unexpected ground loop source
joeparaski
Alright, after doing some research I bought a ground fault detector and a low-voltage detector and got to work trying to find the source of the buzzing sound.
One of the tips was to disconnect everything and plug stuff back in to try and isolate the offending component.
I've got a lot of components, but I did find that 2 of the Bose 1801 amps were contributing to the buzz. A couple of cheater plugs solved that problem but there was still a buzz present when the Samsung t.v. was plugged in.
What?? The t.v!!!??? Even when it's OFF!!!!??? Amazingly the Samsung plasma causes a buzzing sound in the speakers even if it is off. I tried plugging the t.v. into a completely different circuit from the sound system and it still does it!
Joe
Joe
Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
Post edited by joeparaski on
I've read here on the forums that the RG6 coax cable from the cable tv service can sometimes cause noise problems.???
If thats the case, run the coaxial cable through a power conditioner if it has said in/outputs maybe? Mine has ins/outs for that and telephone plugs too, but I just dont use them.Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
I don't have cable tv service so I don't have a coaxial cable. Very strange, the buzz gets noticeably louder when the t.v. is physically plugged into the wall outlet.
JoeAmplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96. -
Is the tv....3 prong? There might not be a proper ground at said outlet. Something you can check with a multimeter, and easy to rewire.Truck setup
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
Run the TV to a remote outlet with an extension cord. Just something to try.____________________
Pool: Atrium 60's/45's -
Btw, if you own a power conditioner and are NOT using the coaxial ins/outs from the wall to your conditioner and then out to your satellite/cable box then youre missing out. Noticeable difference in sound and slightly better picture. There was a faint 'hiss' on several non-hd channels and theyre ALL gone since I decided to hook it up just half an hour ago. Just thought I'd shareTruck setup
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
What model Samsung, have you done a search to see if this is common with that model?
For example:http://www.avsforum.com/avs-vb/showthread.php?t=791737&highlight=samsung+buzz
Is the buzzing coming from the TV or is the TV creating a buzzing in your audio gear?
