Dynamat Extreme
Toolfan66
I put some Dynamat Extreme in my 1.2tl's today.
Right now I just did the crossover plates, and the passive driver,and I used RUSH Tom Sawyer for my test.
I am not sure if doing the crossover plates help any, but just doing the passive gave me a much tighter more detailed bass response.
Thanks to F1nut for pushing me to do this sooner then later.
I will do the drivers this week, and see what else I find using the DE.
On another note I found that my stuffing keeps sliding down. Anybody else find this problem with there SDS SRS's?
What can I use to keep this from happening? I thought about using velcro.
Post edited by Toolfan66 on
Try putting a little glue on it and attaching it to the side of the cabinet.
Hot glue works well."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
I stapled mine up and so far no issues...Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Is Amazon the best bet to buy the DE?
Do you just cover the speaker baskets, or do you line the inside of cabinet as well? I was thinking of trying this with my LSi's....
Michael
Just the baskets. I've seen a spray that might work for the cabinets. -
There's a bunch on ebay, Does anybody know how much I would need for both 1.2tl's ?
http://cgi.ebay.com/NEW-DYNAMAT-EXTREME-WEDGE-PACK-NEW_W0QQitemZ320397764285QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item4a9931e6bd&_trksid=p3286.c0.m14&_trkparms=65%3A12%7C66%3A2%7C39%3A1%7C72%3A1234%7C293%3A1%7C294%3A50
Thanks,
Sal
Less than one sheet did mine. -
I haven't check my PMs today as of yet. I'll check them now.
Thanks,
Sal
One sheet will do, I bought a box of 9 and have 8 left...I will use it on another project I guessPio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
http://www.polkaudio.com/forums/showthread.php?t=73909
Here is what I did. I guess I went a little over board but what the hell. -
I guess I should have asked on this discussion... Can anyone provide pics on the proper way to achieve this?TOOLFORLIFEFAN wrote: »Yep 1 sheet..
Joe did you get my PM?
Thanks;
TKDARE TO SOAR:
Here is my thread on Dynamating my 1.2 TLs. It has pictures.
http://www.polkaudio.com/forums/showthread.php?t=52810&highlight=Dynamated -
Hey Hearing Im impressed I havent been home much lately but this sounds like a Niice tweak !!! Alway used dynomat in the trucks and cars never really thought about it in the TL's:cool: " He who dies with the most equipment wins Right ? "
Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center,HPSA-1000 18" sealed DiY home sub.:D
Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables -
will this void any warranty issues with polk?Fronts L/R: Polk Rti-a9
Center: Polk CSi-a6
Surrounds L/R: Polk Rti-a7
Subs: Velodyne DPS12
Receiver: Denon AVR 4306
Source: HTPC tower/360 elite
Panamax Power Conditioner
AudioQuest Type 4 Cables -
Considering the SDA's are about 20 years old, warranty is not a issue.
bumpI refuse to argue with idiots, because people can't tell the DIFFERENCE!
Sweet! I actually got some Dynamat Extreme, and some Mortite, a couple weeks ago. I haven't installed it yet though. I'm gonna go ahead and do both my 2A's and my Monitor 7A's.
I'm looking forward to hearing some improvements!The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
If the whole point of using dynamat on speaker baskets is to damp resonance by adding mass, wouldn't mortite work just as well, besides being a lot cheaper?
Considering that Dynamat Extreme is designed for said purpose and Mortite is designed to caulk doors and windows......ya know!?!Political Correctness'.........defined
President of Club Polk -
Other folks have been using Mortite to damp speaker baskets as well with good results, but I don't recall seeing anybody here do it. Maybe I'll just do it just out of curiosity
Ugh, defies logic. Besides, Dynamat Extreme is not expensive.Political Correctness'.........defined
I'd say you will not have any luck with the mortite staying in place unless you glue or tape it on. It does not have much sticking ability on a flat surface. I have a feeling it would just fall off eventually. The Dynamat will stick really good, and do the job it was intended to do. Go ahead and experiment with the mortite if you want. It's your time and money
Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
http://www.douglasconnection.com -
Mortite is a caulk sealer and won't do much to dampen the speaker baskets. Not only that and just to add what has been said above, if you do try it and find it doesn't work you will have to scrape it all off with a knife and then Dynamat. Why go through all that when you can get the a sheet of Dynamat, for not a lot of money, as it is designed to stick and dampen? -
Mortite would be a "HUGE" waste of time, Just get the Dynamat Extreme..
It just takes one sheet for both sets of 1.2? how big was the sheet? I see them on amazon at different sixes.
Hey bub, I when I did my 1.2TLs I had a little left over and I am heavy handed. However I bought the large box of four sheets which possibly the sheets are bigger than the ones that come in lesser amounts. -
Were the sheets you used by any chance this pack on Amazon
http://www.amazon.com/Dynamat-10435-Xtreme-Door-Sheets/dp/B00020CAUG/ref=sr_1_2?ie=UTF8&s=automotive&qid=1284263152&sr=8-2-spell
its a 4 pack of 1 by 3 feet sheets -
Yep! That be it.:) It looks just like the box I have. I'm glad I got the big pack in that Dynamat has so many uses both on gear and speakers as well as noisy household items. -
I was trying to find this locally so I can go over and pick it up this evening and came across this stuff
http://www.oreillyauto.com/site/c/detail/RBL0/138.oap?keyword=dynamat
Its called RBL Products - Xtreme Dyn and is supposed to be the same thing. Anyone heard of this?
