Linksys wrt54g issues again.
disneyjoe7
disneyjoe7 Posts: 11,435
edited January 2010 in The Clubhouse
I think I need to replace my router again, it keeps dropping my broadband connection. My last one would drop the wireless connection output, by now this one is a different issue all together. It seems these router have a limited lifespan, Linksys / Cisco home stuff is nothing like the commercial stuff :rolleyes:
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR
Post edited by disneyjoe7 on
  • AudioGenics
    AudioGenics Posts: 2,567
    edited July 2009
    who is the broadband provider ?
    dsl, fios, cable, WiFi ?
  • nguyendot
    nguyendot Posts: 3,594
    edited July 2009
    I have 6 WRT54G's and they all work wonderfully. First thing I do when I get them is dump DD-WRT on them so they don't have the log full error.
    By default the WRT54G keeps a log of all incoming and outgoing connections for like a week. The problem is that if you make a lot of connections (such as bitorrent), the log will fill up and crash the router. The new firmware makes it more stable by fixing that problem, as well as quite a few others. Not to mention it adds QoS (quality of service) so that when you're downloading and uploading a lot, you can still set HTTP as a premium service and it will not lag.
    Main Surround -
  • AudioGenics
    edited July 2009
    great info !
    I needed that also....
    billbillw Posts: 7,550
    edited July 2009
    I've been using a WRT54G for 4 years with no problems. Perhaps the problem is with your modem this time.
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited July 2009
    I also use DD-WRT on the same router and MUCH prefer it to the standard firmware. One great feature is it lets you adjust the watts for your wireless signal output, therefore effectively letting you increase your range - you gotta ba careful with that feature because you can cook it, but that's why I switched and it works great!
  • Systems
    Systems Posts: 14,873
    edited July 2009
    Hello
    Belkin made this router when the "pre-n" craze first started. I've had zero issues with this router, its on 24/7, never have to restart it. Its feeding three towers, a 360, and wireless its feeding a ps3, psp, laptop, and directv on demand.
    Every time I see people having router issues I point them to this router....continue to pull your hair out with other routers...or live in peace....your call....
    http://cgi.ebay.com/Belkin-Wireless-Pre-N-F5D8230-4-Router-Brand-New_W0QQitemZ260444554250QQcmdZViewItemQQptZCOMP_EN_Routers?hash=item3ca3b4840a&_trksid=p3286.c0.m14&_trkparms=65%3A12|66%3A2|39%3A1|72%3A1234|293%3A1|294%3A50
    Testing
    Testing
    Testing
  • AudioGenics
    edited July 2009
    Belkin looks like a good product alternative.....
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited July 2009
    I just picked up a D-Link Xtreme N Wireless-N Gigabit Router about 5 or so months ago. Had an old Lynksys and it kept locking up on me when more than one source was pulling a signal off of it. With the D-Link I have 2 PS3's, an XBox 360, and a laptop usually on at the same time and no issues what so ever. For around $100 bucks, you can't beat it IMO.
    http://www.bestbuy.com/site/olspage.jsp?skuId=8040121&type=product&id=1157068454881
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • Pauly
    Pauly Posts: 4,519
    edited July 2009
    +1 on the D-Link. Havent had any issues with mine.
    Life without music would
  • Serendipity
    Serendipity Posts: 6,975
    edited July 2009
    I kept cooking routers until I put them in a nice, cool location. It seems like heat shortens their lifespan.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • engtaz
    engtaz Posts: 7,669
    edited July 2009
    I was having the same thing happen. Had to unplug the router and replug it to get it to work. Now it has not happened in over a week. Cable provider is a pain tho.
    engtaz
  • bruss
    bruss Posts: 1,039
    edited July 2009
    I have had mine for a long time with no problems. It is now only serving wifi access as the cisco 3620 took over as my gateway.
  • disneyjoe7
    edited July 2009
    Hmmm.... I thought I posted this before, but I don't see it now. Issues? please PM me. I posting it again as not sure.
    My log is off, and was off before also.
    My software is this v8.00.5 current is v8.00.6 not sure if this would be an issue or not.
    Modem being the issue?
    Quote from Linksys.
    Linksys, A Division of Cisco
    Product: WRT54G V8
    Classification: Firmware Release History
    Release Date: Jul 01, 2008
    Last Firmware Version: 8.00.6
    _____________________________________________________________________
    General Notes:
    - This firmware is compatible with WRT54G hardware version 8 only. Please check the bottom of your router to make sure you have the correct version.
    - Disconnect all wireless clients from the router during the upgrade process. Make sure no wireless clients attempt to associate with the router until the upgrade process is complete.
    Firmware 8.00.6
    - Adds Linksys EasyLink Advisor (LELA) 3 support.
    - Adds dynamic PPTP support.
    (NOTE: Firmware 8.00.6 is not compatible with Linksys EasyLink Advisor (LELA) version 1.6. If you would like to continue to use LELA 1.6, do not upgrade the router with this firmware.)
    Firmware 8.00.5
    - Resolves issue with Linksys EasyLink Advisor.
    - Resolves issue with using a WAP54G in repeater mode.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • disneyjoe7
    edited July 2009
    appadv wrote: »
    I always wonder if this is an issue living in Florida. The unit is very warm, my dsl modem is under a hub also, so this isn't very cool either. My units seem to live for 18-24 months before they **** the bed. ;) The only I think I could do is add a fan to try to keep them cool.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Sherardp
    Sherardp Posts: 8,038
    edited July 2009
    I dumped mine and went with D-link all around. Two D-link DIR-615s and a 8 port 10/100/1000 D-link Switch.
  • nguyendot
    edited July 2009
    I'm going to mod my WRT54G with an SD card slot and a fan... It'll probably keep it stable forever. I was running two 1 watt amps (in and out) for a long while.
    The airport next to me was NOT happy.
    Main Surround -
  • bobman1235
    bobman1235 Posts: 10,822
    edited July 2009
    +1 on swapping out the Linksys firmware for DD-WRT. Great alternative, and it seriously helped with my crashes. Mine runs 24/7 and hasn't given me an issue in years.
    D-Link is a fine alternative though; I like their products.
    But Belkin? The only routers worse than Belkins are Netgears, at least on the lower-end consumer stuff. I had THREE of those little grey Belkin routers (don't remember the model numbers) and they were ALL buggy as ****.
  • nguyendot
    edited July 2009
    I never liked the old belkin routers. Constant crashes.
    The newer stuff is great. The only DLINK i've ever liked was that gaming router. It was actually one of the best of all time. The extra ram really made it bulletproof.
    Main Surround -
  • disneyjoe7
    edited July 2009
    What is DD-WRT?
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • nguyendot
    edited July 2009
    http://www.dd-wrt.com/dd-wrtv3/index.php
    It's a linux based open-source (aftermarket) firmware for many different router models. The most popular is the Linksys WRT54G, which was originally linux based which made it easy to change the firmware.
    DD-WRT is just one flavor like Tomato, that gives many more options and usually stabilizes the router. Check out the website. Usually doing this voids your warranty, however, not that it matters.
    Main Surround -
  • Serendipity
    edited July 2009
    bobman1235 wrote: »
    +The only routers worse than Belkins are Netgears, at least on the lower-end consumer stuff. I had THREE of those little grey Belkin routers (don't remember the model numbers) and they were ALL buggy as ****.
    I have a Netgear router that has been working great ever since I switched from Linksys.
    It's been working for 4 years now. Seems to not be as affected by heat, although I do put it in a cool location.
  • disneyjoe7
    edited July 2009
    Thanks for the link, and as far as warranty how cares it's over.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • nguyendot
    edited July 2009
    I wont buy a new Linksys WRT54G however, all the ones V5 and above are inherently unstable.
    Main Surround -
  • bobman1235
    edited July 2009
    appadv wrote: »
    I'm shocked to discover you disagreeing with me on a computer issue! SHOCKED! :rolleyes:
    This was admittedly 6+ years ago, so maybe they have improved, but I threw away enough money on them and my Linksys has been working just fine since.
  • chillywilly
    chillywilly Posts: 167
    edited July 2009
    my linksys lasted less then a year. Got a d-link and its been fine
    FXi3 sats
    RTi10 fronts
    CSi5 center
    velodyne dps 10
    denon avr 888
    velodyne dps 12
    sammy lcd
    ps3 60gig
    wii for family
  • nguyendot
    edited July 2009
    I believe they've all gotten better over the years.
    Back in the day...when WRT54G first came out, they were the best, with the most ram. Belkin sucked, Dlink sucked. Netgear was not bad - it was actually made of steel.
    As time went on Belkin still was horrible until their N series came out and then they hit a sweet spot. Dlink got their gaming router and has had success. Netgear really hasn't gone anywhere. Neither high nor low. Linksys has gone from high to low back to about average. Their WRT54G v5 was horrible, running the non linux vxworks that crashed multiple times daily.
    Main Surround -
  • ViperZ
    ViperZ Posts: 2,046
    edited July 2009
    I like my WRT54G. A lot of interesting info about this router in this thread, will check my firmware status when I'll get home in a couple of weeks.
    Btw, I tried Belkin, Netgear, Microsoft (yes, they make one) and D-Link routers, and regarding area coverage, strength, signal quality and overall impresseion - I like this router the most.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • John30_30
    John30_30 Posts: 1,024
    edited July 2009
    nguyendot wrote: »
    Disneyjoe has v.8, so that's going to have vxworks and a tiny NVRAM also. They have a version of dd-wrt for flashing over vxworks, but it's dicier. I flashed a v5 router just to see if I could make it a wireless repeater for my main router.
    Pretty cool stuff old Brainslayer has added in.
  • nguyendot
    edited July 2009
    i had the Microsoft ones too! They were actually the EASIEST to set up, unfortunately their range was not so great. Overall the router had zero options but worked when i needed it to.
    My preference now is the WRT54GS or GL. They aren't gimped like the v5 and above.
    Main Surround -
  • disneyjoe7
    edited July 2009
    DD-WRT software update?
    When I go there I have 2 files for v8.0?
    dd_wrt.v24_mirco_generic.bin 2009-06-03 1.68mb
    or
    dd_wrt.v24_mirco_olsrd_generic.bin 2009-06-03 1.66mb
    Which one do I download?
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
