Polk RMDS-1 system speaker hum problem
muddog49
My "old" RMDS-1 system has started a loud hum. I've checked all the connections and they seem ok. It does the hum on any input: Cable DVR, DVD, etc. Any thoughts would be greatly appreciated. Thanks
Post edited by muddog49 on
have your professional authorized dealer that sold the unit to you check it or repair as needed.
Hello,
I'm sorry you're having a problem. I'm sure we can be of help, send me an email message at polkcs@polkaudio.com and we can try a few things.
Regards, Ken -
found this old thread/post
not sure if I would believe it but its worth a try as it is simple
https://shop.polkaudio.com/forums/showthread.php?t=20036 -
Thanks for the replies. A friend who is pretty knowledgeable about these things said to get a ground loop isolator. I found one on Amazon for $25. It has coax connections on each end. I put it between the cable TV coax and the cable box/DVR and the hum went away. Now everything sounds good again. May not be the best way to fix it but it works. Thanks
which one did you buy from Amazon ?
there are tons of ground loop isolators
http://www.amazon.com/s/ref=nb_ss_gw?url=search-alias%3Daps&field-keywords=ground+loop+isolator&x=0&y=0 -
also items called Isolation Transformer...
see that this one was for coax
may this one ? -
like to know as well -
The one I got from Amazon was the Viewsonics VSIS-EU Cable TV Ground Loop Isolator, $25
Kenneth Swauger wrote: »Hello,
Regards, Ken
Muddog49, Shoot Ken an email, he is your best option.Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
greymatter wrote: »like to know as well
Greymatter....your back! your almost at 25 posts, the suspense is killing me to see what you have for sale!Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
