Minor emergency with my TL's
nooshinjohn
I pulled the drivers tonite to replace the polyfill inside the speakers only to find that eveything is wired out of phase! I don't know why I was unable to hear that but all drivers in both arrays are wired incorrectly.:eek:
I have so far had no issues putting things back the way they should be with exception of the third driver from the bottom. I have no doubt the wiring is factory true. the driver in question has a black AND a white wire connected to the same terminal. Is this correct?
thanks for the help!
John
John
Post edited by nooshinjohn on
Wiring diagrams for the 1.2TL's can be found in the SDA schematics thread in the Vintage Speakers forum section.Proud and loyal citizen of the Digital Domain and Solid State Country!
added to the above... on the back side of the of the crossover... should there be anything soldered to the circuit board of ANY kind...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
I have looked at those, and I think I figured out what they were doing on that one. I am confused by the crossovers at this moment however...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
nooshinjohn wrote: »added to the above... on the back side of the of the crossover... should there be anything soldered to the circuit board of ANY kind...
Your pictures are not clear enough for me to see what you mean. If you are asking if any wires should be soldered to the crossover board, the answer is no. All wiring should connect to the crossover board with snap-in wiring harnesses.Proud and loyal citizen of the Digital Domain and Solid State Country! -
I figured that as well DK... it would appear that there have been some un-needed mods made to these. I am refering to all the yellow caps that have been added to the backside of the crossover itself. All the wiring thankfully is soldered to the board in the proper locations on the board. take a peek at pictures two and three and you will see what I am taliking about.
Thanks for taking the time DK, I am grateful for the time.
PM sent.
JohnThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Perhaps the yellow caps are bypass film caps for the electrolytics. I have heard of people doing that when they didn't want to replace the electrolytics.Proud and loyal citizen of the Digital Domain and Solid State Country!
so I should plan on taking them down and getting them rebuilt soon then?
lol... should I try and run them with the phase corrected then and not worry about the crap on the back?
Be careful with changing the wiring..... SDA's wiring can look weird.
This diagram is for the 1.2 TL's and you can see how wires go from - to + both in the SDA and Stereo sides.
nooshinjohn wrote: »so I should plan on taking them down and getting them rebuilt soon then?
I think it would be a good idea to rebuild the crossovers simply due to the age of the electrolytic caps. If you don't want to go to the time and expense of replacing the electrolytics with film caps, I would recommend replacing the electrolytics with new electrolytics.nooshinjohn wrote: »lol... should I try and run them with the phase corrected then and not worry about the crap on the back?
You should figure out what the yellow caps are connected to.Proud and loyal citizen of the Digital Domain and Solid State Country! -
The black and white are likely crimped together to facilitate a series connection which it appears both arrays are wired in a series/parallel config.Testing
Testing
Testing -
thanks guys... I got the wiring troubles figured out... now for the damn crossover.
I wish I could figure out what the damn caps are doing there. The guy Igot them from says they were done to improve sound quality and nothing more. He also said he assumed they were wired correctly when he put them back in as Black is ground everywhere else but here. He said the crossover mods will not affect the wiring being corrected as I have done, so I am going to fire them up and give a listen
well.. They now sound even better! With the phase issues corrected and the new polyfil in place they sound as if a veil has been lifted from them. I would not have gotten them done tonight without you guys! Ricardo, the diagram was a lifesaver!
Thanks Guys.
This is a great help, Thank you!!!!:DPio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
How did you arrive at that conclusion?Political Correctness'.........defined
President of Club Polk -
white and green were running to the positive side of the driver, as identified by the little red dot. The should have been black and blue, just like I am now after wrestling with these beasts all day.
Ok in that case, they were wired incorrectly. Have you checked the tweeters as well?Political Correctness'.........defined
yes.. they were all correct, but the top two were disconnected.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
It's good that you have rescued these speakers.
Those yellow caps are either Auricap or Kimber (made by Auricap) and I agree with Raife that they are probably bypass caps. Get rid of them when you upgrade the crossovers.Political Correctness'.........defined
I am looking into parts now. Is there any way to restore the plug in connectors or is that screwed forever...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Mouser will have them.Political Correctness'.........defined
who is Mouser. Is this for the connectors or the crossover parts.Mouser will have them.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
GD's got it. Look at the Molex or AMP rectangular connectors.Political Correctness'.........defined
Okay, who is GD??Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
george daniel wrote: »I am GD;)
Good to know!!Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
And he's real sweetheart to boot.:DGood to know!!
Great job on the TL's John. Looking sweet. After you finish the x-overs, they should be mind blowing!
Keep up the good work, ya freak! -
Thanks Lightmanfor your kind words... but one guy calling another a sweetheart? That's freaky:pAnd he's real sweetheart to boot.:D
Keep up the good work, ya freak!The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
You haven't met George yet. He's a peach!nooshinjohn wrote: »Thanks Lightmanfor your kind words... but one guy calling another a sweetheart? That's freaky:p
