Psw111
Fud
Fud Posts: 16
edited August 2009 in Troubleshooting
the instructions for option 1 are different between the one posted on the website and the manual that came with the unit.the manual says i should hook the rca into the lfe imput on the subwoofer with no reference to setting the lfe switch.which version is correct?
Post edited by Fud on
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited July 2009
    I would hook up all the speakers to the AVR and let it power them. Then use a subwoofer cable and hook up one end to the LFE IN on the back of your sub and hook the other end up to the Subwoofer Pre-Out on the back of your AVR. Then make sure you go into your AVR options and make sure the Subwoofer option is set to "On" "Yes" or "Present" or whatever may apply. Set the crossover on your fronts/mains to 80hz and you should be good. Good luck and welcome to Club Polk.
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • Knucklehead
    Knucklehead Posts: 3,602
    edited July 2009
    yep, what wutadumsn23 said. Also, make sure you are playing a source that has some good bass to check your system. Welcome.
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • Fud
    Fud Posts: 16
    edited July 2009
  • royalty
    royalty Posts: 246
    edited July 2009
    How loud is this psw111
    HOME AUDIO:
    Electronics:
    HK 354
    Front Power: CARVER TFM-35
    Center Power: Audiosource Amp One
    Speakers:
    Center: CSi5
    Fronts: rti10s
    Rears: monitor 50s
    psw 125 + psw 505 = BOOM
    CAR AUDIO
    Infinity 6032CF's all around
  • Fud
    Fud Posts: 16
    edited July 2009
    actually it does seem kind of low.i was going to assume that it just "blends" well.the impact is so indirect im not sure now.i do get volume out of it for the deep lows with it set at -3db on the avr and full volume on the sub.it does blend very well with tsi200 fronts.but i dont seem to get enough volume from anything but deeep lows.
  • Conradicles
    Conradicles Posts: 6,119
    edited July 2009
    Fud wrote: »
    enough volume from anything but deep lows.
    That is exactly what you want a sub to do. Nice little sub.
  • Fud
    Fud Posts: 16
    edited July 2009
    yes i am actually very pleased with it.it blends so well i dont care if its right or wrong.it is a solid,well built unit,with a very nice finish on it.it is compact and fit the space i had picked out for it perfectly.it made my 2.1 set up with tsi200's as the mains sound complete,no lack.its my first sub,i had !jbl 3 ways before for the last 11 years.so its been a while since ive upgraded or set anything up(so im not sure when i dont have something hooked up right).the set up i have is obviously no power house but the overall depth of the sound seems a little low.ive got an old jinx about setting stuff up anyway.:cool:
  • SivaNevets
    SivaNevets Posts: 303
    edited July 2009
    ive audited this little sub at futureshop and surprised how tight and articulate the bass is, im considering to get this sub because it produce the sound i want (i dont like boomy bass).
    my question is how deep can this sub go? i enjoy the deep bass from movie scence as well. how do they compare to PSW10 in a mid sized living room?
    (they r on sale right now 37% off the regular price $250 CDN, not very hot but not bad either)
    this will be pairing up with RTI6 by the way.
    Front: Martinlogan ESL
    Center: Martinlogan Stage
    Rear: Martinlogan Motion 4
    Sub: Martinlogan Grotto-I
    Receiver: Pioneer Elite SC 1523K
    PC 2 Channel: Polk LSI7
    Headset: Grado RS2 + Grado RA1 amp
    Mic: Neumann KMS605
    Car Audio
    2002 MB C240 Sedan
    MM6501 components
    MM840 sub
    MB Quart Onyx 4.60 (1/2 to components, 3/4 bridged to sub)
    Pioneer 8200BT HU
  • Fud
    Fud Posts: 16
    edited August 2009
    the back of this sub gets extremely hot under normal use,is this normal?the sub is capable of the "movie boom" but thuds crunches and booms all kinda sound the same.it blends very well with music however there is a lack of definition for the bass.using it with an onkyo 607 it cannot play very loud,or there is a definite sense of a lack of power with it.
  • apphd
    apphd Posts: 1,514
    edited August 2009
    Fud wrote: »
    Just me but I would try turning the volume on the sub down a little and up some in the AVR.
