Polk Micropro 1000 Hum...
Polkitup2
Polkitup2 Posts: 1,642
edited June 2009 in Troubleshooting
Just today my Polk Micropro 1000 started emitting a noticeable hum. Not loud, but annoying on soft passages. It used to be dead quiet. I unplugged all connections and plugged the sub into various outlets throughout the house and got the same hum through the driver - definately coming through the driver. Changed power cords, same hum. Checked to make sure nothing new was running power in the house and unplugged all those items, disconnected the house cable TV feed, and checked all the usual subwoofer hum/ground loop scenarios. Guess I going to have to give Polk a call tomorrow unless you guys have any ideas?
Post edited by Polkitup2 on
  • kawizx9r
    kawizx9r Posts: 5,150
    edited June 2009
    Well you've trouble shooted it and found out it isn't RF interference. I had the same problem with my powered tower. When the sub came on, and remained on (for the 10-15minutes before auto shut off) it produced a low hum, and actually turned significantly louder if you turned up the sub volume up. I talked to Polk CS and they responded rather quickly, telling me they would check it out if I sent in my amp and give me a free estimate. It may need to be serviced/replaced, but could just be something small, like some kind of ground loop problem/etc, something coming lose inside the amp.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • kawizx9r
    edited June 2009
    "Sorry to hear about your speaker, if one speaker is buzzing I'd recommend sending the back panel (where the electronics are) of the unit to our factory service center. Unplug the unit from the wall, unscrew the larger screws around the back panel, then the back panel will remove. You'll see a series of quick disconnect wires, they are all removable by hand. Pack the panel up and send it to:
    Polk Audio
    2550 Britannia Blvd
    Suite A
    San Diego CA 92154
    Please include a note with your name, address, phone number, description of the problem and we'll give you a free estimate. Currently we're in the middle of moving our repair/service facility, so there may be a slight delay in service."
    This is what I got in quick response from Polk CS. Hope it helps
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • Polkitup2
    edited June 2009
    Thanks, mine should still be under warranty as it is only a couple months old.
  • kawizx9r
    edited June 2009
    Yea I was going to mention that. Hope everything works out with your sub, btw how are you liking it and what made you go with Polk as opposed to the highly acclaimed SVS or such? I'm still looking into SVS but the new Polk line sound very tight and accurate.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • Polkitup2
    edited June 2009
    Actually, my HT sub is an SVS pb12 plus/2, I bought the Polk sub for my 2 channel system. The Polk has worked well in my system because it is small and blends well with my 2 channel system. I am guessing the larger Polks would also work well for HT.
