Project RM-5 Custom Made Aluminum Clamp
BaggedLancer
Found this while cleaning out the closet. A machinist friend of mine made this for my Project RM-5 table(now sold). It's made out of aluminum, has a few minor surface scuffs that should polish out. They aren't gouges, just the "scuffs" that raw aluminum gets.
Be a nice piece to anodize or just polish and use as is.
$80/obo takes it
$80/obo takes it
Post edited by BaggedLancer on
Is it much different than the standard clamp that comes with the RM-5?
Thanks. -
PM sent.
PM has been returned, Dawgfish was inquiring about it fitting a Technics table. I have no idea. I know it fits an RM5.
Does anybody know if this would fit a Technics SL-1200 MK2? Thanks in advance.
Mark is that clamp threaded?
engtaz,
I believe I'm just going to go ahead and get a clamp specifically made for the 1200, so if you want to take a crack at getting the clamp, by all means go right ahead. Baggedlancer, thanks for your replies. I hope everything works out with your sale.
Steve -
Except for the colour it looks identical to my Pro-ject 6.9 standard clamp, so I would take a very logical guess and say "yes" it is threaded.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
i'm out thanks for the chance.engtaz
oooh, that would make a nice head smacker.
Price drop to $60.
Thanks.
Same question(s).
Is it threaded/heavier/otherwise different?
Thanks. -
Threaded, a little heavier, looks cooler and you can finish it how you want.
