SurroundBar SDA IHT, Sub emitting high pitch whine
PAudio
I have recently purchased and setup a SurroundBar SDA IHT.
However the when in use the Sub gives off a high pitch whine. It's not very load but definitely noticeable.
Is this something other users have experienced? Can it be resolved? Or is my unit faulty?
Dan
Dan
Post edited by PAudio on
Have you tried customer service? Polk does have good reps to help you If anyone is knowledgeable about this issue I'm sure they will chime in.
do you have good cables? might be a ground loop issue or electrical noise from your house wiring, try another outlet.
Thanks for your replies.
I tried different cables, and outlets and I had the same issue.
Being based in the UK I've had to contact the distributer as I cannot contact Polk Direct, they advised me to try reseating, and swapping the Fuse round, which had no effect.
I’m in the process of getting it swapped out.
Will let you know what happens
Dan
